Hello all,
I encounter "error 125: AGDI: memory write failed" when trying to modify a value via a breakpoint command in a .ini script; however, the modification succeeds when manually entering the same command in the Command Window.
Will someone please explain this discrepancy and how to overcome it?
Thank you,
Ira
