Implementing a non-hanging USB listener
I'm working with an LPC1768(FBD100) and need to connect to a PC through a serial USB. As a starting point, I used the sample package USB virtual com port.
Installed packages:
My code:
#include "includes.h"
int main (void) {
MenuEntryVType* MenuEntry;
GUI_Init();
WM_SetCreateFlags(WM_CF_MEMDEV);
FRAMEWIN_SetDefaultSkinClassic();
PROGBAR_SetDefaultSkinClassic();
SCROLLBAR_SetDefaultSkinClassic();
FRAMEWIN_SetDefaultFont(StdFont);
InitOutputs();
InitADCs();
InitDAC();
InitPWM(100);
InitI2C();
GetConfig();
osDelay(1500);
// Works as expected ; new COMx device shows in dev manager.
USBD_Initialize (0U); // USB Device 0 Initialization
USBD_Connect (0U); // USB Device 0 Connect
// menu handling code
// actual functionality start servos, etc.)
// does not get executed. Why?
return 0;
Why does USBD_Connect() hang? no code gets executed past that point; the lpc1768 does connect, however, to the PC:
rl_usb.h contains the definitions of USBD_Initialize() and USBD_Connect():
/// \brief Initialize USB Device stack and controller
/// \param[in] device index of USB Device.
/// \return status code that indicates the execution status of the function as defined with \ref usbStatus.
extern usbStatus USBD_Initialize (uint8_t device);
/// \brief Activate pull-up on D+ or D- line to signal USB Device connection on USB Bus
extern usbStatus USBD_Connect (uint8_t device);
These are function declarations; I don't know where the implementations are (likely in USB_CM3_L.lib).
Read/write functions are defined in USBD_User_CDC_ACM_UART_0.c
 * MDK Middleware - Component ::USB:Device
 * Copyright (c) 2004-2019 ARM Germany GmbH. All rights reserved.
 * Name:    USBD_User_CDC_ACM_UART_0.c
 * Purpose: USB Device Communication Device Class (CDC)
 *          Abstract Control Model (ACM) USB <-> UART Bridge User module
 * Rev.:    V1.0.3
 * \addtogroup usbd_cdcFunctions
 * USBD_User_CDC_ACM_UART_0.c implements the application specific
 * functionality of the CDC ACM class and is used to demonstrate a USB <-> UART
 * bridge. All data received on USB is transmitted on UART and all data
 * received on UART is transmitted on USB.
 * Details of operation:
 *   UART -> USB:
 *     Initial reception on UART is started after the USB Host sets line coding
 *     with SetLineCoding command. Having received a full UART buffer, any
 *     new reception is restarted on the same buffer. Any data received on
 *     the UART is sent over USB using the CDC0_ACM_UART_to_USB_Thread thread.
 *   USB -> UART:
 *     While the UART transmit is not busy, data transmission on the UART is
 *     started in the USBD_CDC0_ACM_DataReceived callback as soon as data is
 *     received on the USB. Further data received on USB is transmitted on
 *     UART in the UART callback routine until there is no more data available.
 *     In this case, the next UART transmit is restarted from the
 *     USBD_CDC0_ACM_DataReceived callback as soon as new data is received
 *     on the USB.
 * The following constants in this module affect the module functionality:
 *  - UART_PORT:        specifies UART Port
 *      default value:  0 (=UART0)
 *  - UART_BUFFER_SIZE: specifies UART data Buffer Size
 *      default value:  512
 * Notes:
 *   If the USB is slower than the UART, data can get lost. This may happen
 *   when USB is pausing during data reception because of the USB Host being
 *   too loaded with other tasks and not polling the Bulk IN Endpoint often
 *   enough (up to 2 seconds of gap in polling Bulk IN Endpoint may occur).
 *   This problem can be solved by using a large enough UART buffer to
 *   compensate up to a few seconds of received UART data or by using UART
 *   flow control.
 *   If the device that receives the UART data (usually a PC) is too loaded
 *   with other tasks it can also loose UART data. This problem can only be
 *   solved by using UART flow control.
 *   This file has to be adapted in case of UART flow control usage.
//! [code_USBD_User_CDC_ACM]
#include <stdbool.h>
#include "rl_usb.h"
#if defined(RTE_CMSIS_RTOS2)
  #include "cmsis_os2.h"
#if defined(RTE_CMSIS_RTOS2_RTX5)
  #include "rtx_os.h"
#endif
#endif
#if defined(RTE_CMSIS_RTOS)
  #include "cmsis_os.h"
#endif
#include "Driver_USART.h"
// UART Configuration ----------------------------------------------------------
#define  UART_PORT              1       // UART Port number
#define  UART_BUFFER_SIZE       512     // UART Buffer Size
#define _UART_Driver_(n)        Driver_USART##n
#define  UART_Driver_(n)       _UART_Driver_(n)
extern   ARM_DRIVER_USART       UART_Driver_(UART_PORT);
#define  ptrUART              (&UART_Driver_(UART_PORT))
// External functions
#ifdef   USB_CMSIS_RTOS
extern   void                   CDC0_ACM_UART_to_USB_Thread (void const *arg) __attribute((noreturn));
#endif
// Local Variables
static            uint8_t       uart_rx_buf[UART_BUFFER_SIZE];
static            uint8_t       uart_tx_buf[UART_BUFFER_SIZE];
static   volatile int32_t       uart_rx_cnt         =   0;
static   volatile int32_t       usb_tx_cnt          =   0;
static   void                  *cdc_acm_bridge_tid  =   0U;
static   CDC_LINE_CODING        cdc_acm_line_coding = { 0U, 0U, 0U, 0U };
// Called when UART has transmitted or received requested number of bytes.
// \param[in]   event         UART event
//               - ARM_USART_EVENT_SEND_COMPLETE:    all requested data was sent
//               - ARM_USART_EVENT_RECEIVE_COMPLETE: all requested data was received
static void UART_Callback (uint32_t event) {
  int32_t cnt;
  if (event & ARM_USART_EVENT_SEND_COMPLETE) {
    // USB -> UART
    cnt = USBD_CDC_ACM_ReadData(0U, uart_tx_buf, UART_BUFFER_SIZE);
    if (cnt > 0) {
      ptrUART->Send(uart_tx_buf, (uint32_t)(cnt));
  if (event & ARM_USART_EVENT_RECEIVE_COMPLETE) {
    // UART data received, restart new reception
    uart_rx_cnt += UART_BUFFER_SIZE;
    ptrUART->Receive(uart_rx_buf, UART_BUFFER_SIZE);
// Thread: Sends data received on UART to USB
// \param[in]     arg           not used.
#ifdef USB_CMSIS_RTOS2
__NO_RETURN static void CDC0_ACM_UART_to_USB_Thread (void *arg) {
#else
__NO_RETURN        void CDC0_ACM_UART_to_USB_Thread (void const *arg) {
#endif
  int32_t cnt, cnt_to_wrap;
  (void)(arg);
  while (1) {
    // UART - > USB
    if (ptrUART->GetStatus().rx_busy != 0U) {
      cnt  = uart_rx_cnt;
      cnt += ptrUART->GetRxCount();
      cnt -= usb_tx_cnt;
      if (cnt >= UART_BUFFER_SIZE) {
        // Dump data received on UART if USB is not consuming fast enough
        usb_tx_cnt += cnt;
        cnt = 0U;
      if (cnt > 0) {
        cnt_to_wrap = (int32_t)(UART_BUFFER_SIZE - ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1)));
        if (cnt > cnt_to_wrap) {
          cnt = cnt_to_wrap;
        cnt = USBD_CDC_ACM_WriteData(0U, (uart_rx_buf + ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1))), cnt);
        if (cnt > 0) {
          usb_tx_cnt += cnt;
    osDelay(10U);
#ifdef USB_CMSIS_RTOS2_RTX5
static osRtxThread_t        cdc0_acm_uart_to_usb_thread_cb_mem               __SECTION(.bss.os.thread.cb);
static uint64_t             cdc0_acm_uart_to_usb_thread_stack_mem[512U / 8U] __SECTION(.bss.os.thread.stack);
#endif
static const osThreadAttr_t cdc0_acm_uart_to_usb_thread_attr = {
  "CDC0_ACM_UART_to_USB_Thread",
  0U,
 &cdc0_acm_uart_to_usb_thread_cb_mem,
  sizeof(osRtxThread_t),
 &cdc0_acm_uart_to_usb_thread_stack_mem[0],
#else
  NULL,
  0U,
  NULL,
#endif
  512U,
  osPriorityNormal,
  0U,
  0U
#else
extern const osThreadDef_t os_thread_def_CDC0_ACM_UART_to_USB_Thread;
osThreadDef (CDC0_ACM_UART_to_USB_Thread, osPriorityNormal, 1U, 0U);
#endif
// CDC ACM Callbacks -----------------------------------------------------------
// Called when new data was received from the USB Host.
// \param[in]   len           number of bytes available to read.
void USBD_CDC0_ACM_DataReceived (uint32_t len) {
  int32_t cnt;
  (void)(len);
  if (ptrUART->GetStatus().tx_busy == 0U) {
    // Start USB -> UART
    if (cnt > 0) {
// Called during USBD_Initialize to initialize the USB CDC class instance (ACM).
void USBD_CDC0_ACM_Initialize (void) {
  ptrUART->Initialize   (UART_Callback);
  ptrUART->PowerControl (ARM_POWER_FULL);
  cdc_acm_bridge_tid = osThreadNew (CDC0_ACM_UART_to_USB_Thread, NULL, &cdc0_acm_uart_to_usb_thread_attr);
#else
  cdc_acm_bridge_tid = osThreadCreate (osThread (CDC0_ACM_UART_to_USB_Thread), NULL);
#endif
// Called during USBD_Uninitialize to de-initialize the USB CDC class instance (ACM).
void USBD_CDC0_ACM_Uninitialize (void) {
  if (osThreadTerminate (cdc_acm_bridge_tid) == osOK) {
    cdc_acm_bridge_tid = NULL;
  ptrUART->Control      (ARM_USART_ABORT_RECEIVE, 0U);
  ptrUART->PowerControl (ARM_POWER_OFF);
  ptrUART->Uninitialize ();
// Called upon USB Bus Reset Event.
void USBD_CDC0_ACM_Reset (void) {
  ptrUART->Control      (ARM_USART_ABORT_SEND,    0U);
// Called upon USB Host request to change communication settings.
// \param[in]   line_coding   pointer to CDC_LINE_CODING structure.
// \return      true          set line coding request processed.
// \return      false         set line coding request not supported or not processed.
bool USBD_CDC0_ACM_SetLineCoding (const CDC_LINE_CODING *line_coding) {
  uint32_t data_bits = 0U, parity = 0U, stop_bits = 0U;
  int32_t  status;
  ptrUART->Control (ARM_USART_CONTROL_TX,    0U);
  ptrUART->Control (ARM_USART_CONTROL_RX,    0U);
  switch (line_coding->bCharFormat) {
    case 0:                             // 1 Stop bit
      stop_bits = ARM_USART_STOP_BITS_1;
      break;
    case 1:                             // 1.5 Stop bits
      stop_bits = ARM_USART_STOP_BITS_1_5;
      break;
    case 2:                             // 2 Stop bits
      stop_bits = ARM_USART_STOP_BITS_2;
  switch (line_coding->bParityType) {
    case 0:                             // None
      parity = ARM_USART_PARITY_NONE;
      break;
    case 1:                             // Odd
      parity = ARM_USART_PARITY_ODD;
      break;
    case 2:                             // Even
      parity = ARM_USART_PARITY_EVEN;
      break;
    default:
      return false;
  switch (line_coding->bDataBits) {
    case 5:
      data_bits = ARM_USART_DATA_BITS_5;
      break;
    case 6:
      data_bits = ARM_USART_DATA_BITS_6;
      break;
    case 7:
      data_bits = ARM_USART_DATA_BITS_7;
      break;
    case 8:
      data_bits = ARM_USART_DATA_BITS_8;
      break;
    default:
      return false;
  status = ptrUART->Control(ARM_USART_MODE_ASYNCHRONOUS  |
                            data_bits                    |
                            parity                       |
                            stop_bits                    |
                            ARM_USART_FLOW_CONTROL_NONE  ,
                            line_coding->dwDTERate       );
  if (status != ARM_DRIVER_OK) {
    return false;
  // Store requested settings to local variable
  cdc_acm_line_coding = *line_coding;
  uart_rx_cnt = 0;
  usb_tx_cnt  = 0;
  ptrUART->Control (ARM_USART_CONTROL_TX, 1U);
  ptrUART->Control (ARM_USART_CONTROL_RX, 1U);
  ptrUART->Receive (uart_rx_buf, UART_BUFFER_SIZE);
  return true;
// Called upon USB Host request to retrieve communication settings.
// \param[out]  line_coding   pointer to CDC_LINE_CODING structure.
// \return      true          get line coding request processed.
// \return      false         get line coding request not supported or not processed.
bool USBD_CDC0_ACM_GetLineCoding (CDC_LINE_CODING *line_coding) {
  // Load settings from ones stored on USBD_CDC0_ACM_SetLineCoding callback
  *line_coding = cdc_acm_line_coding;
  return true;
// Called upon USB Host request to set control line states.
// \param [in]  state         control line settings bitmap.
//                - bit 0: DTR state
//                - bit 1: RTS state
// \return      true          set control line state request processed.
// \return      false         set control line state request not supported or not processed.
bool USBD_CDC0_ACM_SetControlLineState (uint16_t state) {
  // Add code for set control line state
  (void)(state);
  return true;
Is it possible to run the lpc1768 as a USB listener and also perform a set of tasks in parallel? If yes, how should I go about it?
  • About the OS stackspace: the 'bare metal' stack space (defined in the startup.s file) is distinct from the thread stack space (defined in RTX_CM_lib.h). OS_PRIVSTKSIZE is in bytes, not words. RTOS1 is confusing, which is one of the reasons I much prefer RTOS2. You need four user-defined stacks for USB CDC: one for the CDC thread you've defined in ACM_Initialize(), and one each for USB Bulk, USB Core, and USB Interrupt endpoints. These threads are created during USBD_Initialize(), and the debugger makes seeing this easy. Are you able to debug locally?
    Thanks! That cleared it up; I'm still learning :P . I've managed to get the lpc to connect to PC USB host and send a byte stream. Unfortunately, I cannot debug locally (I build the project on a remote machine (keil licensing ...)); I can only display error codes and messages on an LCD. I've used SerialPortStream to read data directly from the lpc1768:
    https://stackoverflow.com/questions/63114656/serialport-fails-to-connect-to-mcu-lpc1768
    I have to make the lpc1768 talk (listen initially) to a dspic30f6013a over VirtualCOM (over USB). Right now both the lpc and dspic can talk to a PC host over serial USB. I'm trying to get the lpc to run into host mode (so that it can directly listen to the dspic) but there seems to be no host component in the USB components' menu:
    These are the components of the USB Host Keyboard sample:
    In my project the USB host component is missing altogether:
    Should I try removing the USB device components? Shouldn't the lpc be able to switch between device and host mode?
  • MDK-Pro is required to enable/provide RTE Manager support for USB hosts. If you change the value of the USB drop-down (partially covered by the arrow in your last screenshot) to MDK-Pro, the Host component will appear. If you only have MDK-Plus then I imagine the path to a functional USB Host is much harder, especially with your licensing arrangement.
    The LPC1759 USB controller supports both device and host modes, although I don't know how much work has to be done to effect the switch at run-time. If you have MDK-Pro it could be as easy as calling USBx_Initialize(), etc. It's not clear how you'd connect to the DSPIC30F6013A over USB when (per Microchip) that part doesn't have a USB port.
    I still think it's worth pursuing either a change to the license to allow local debug, or getting USB virtualization software like VirtualHere to enable debug from the machine with the MDK installed.
  • USBH_CDC_ACM_GetStatus  crashes at some point.
    Thanks! I do have MDK Pro on a remote machine. I was unable to get the lpc to switch from device to host;
    dspic30f6013a only does UART over serial.
    I'll try to debug remotely through VirtualHere ...
