1.when i use printf with no var_args then the compiler should call puts instead of printf.
ex1:
#include <REGX51.H> #include <stdio.h> void main(void) { printf("This must call puts instead of printf"); }
Program Size: data=30.1 xdata=0 code=1103
ex2:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This must call puts instead of printf"); }
Program Size: data=9.0 xdata=0 code=168
The above code links the printf function from the library which is huge(produces 1103 bytes).But the compiler can use puts when there is no var_args given which is much smaller than printf(produces 168 bytes).
2.The Compiler must find and remove the duplicate constant strings
ex3:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=334
ex4:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=183
3.Bit Test instructions are not used when i actually test for the bit
ex5:
#include <REGX51.H> #include <stdio.h> void main(void) { if(P0^1) { P1 = 10; } } ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION main (BEGIN) ; SOURCE LINE # 6 ; SOURCE LINE # 7 ; SOURCE LINE # 8 0000 E580 MOV A,P0 0002 6401 XRL A,#01H 0004 6003 JZ ?C0002 ; SOURCE LINE # 9 ; SOURCE LINE # 10 0006 75900A MOV P1,#0AH ; SOURCE LINE # 11 ; SOURCE LINE # 13 0009 ?C0002: 0009 22 RET ; FUNCTION main (END)
In the above assembly output it should have used a single instruction JNB instead of three MOV,XRL and JZ.This is very basic anybody would object the assembly code produced.
I have not used the compiler much.But the compiler needs a look by the programmers at keil.
The above programs were all compiled with compiler optimisation level set to 9 & favour speed.
About 5 years back i compiled a c51 source code using keil. Now i recompiled the same source code with the latest compiler from keil and compared the two output .hex files. Unfortunately it produced exactly the same output.Here i was expecting some code and data size reduction as the compiler must be capable of optimising more.
It seems there was no improvement on the compiler side.
It is not a complaint but in the interest of improving the compiler.
regards,
S.Sheik mohamed
Well Keil support multiple data pointers so that processors that have them can have compiled code that uses them.
The programmer can choose to use (or ignore) the possible optimisation opportunity.
So theoretically, the same thing could be done with bit access.
It's a simple matter-of-fact.
Keil already have (by necessity) a number of extensions for the '51, so adding another wouldn't really be so naughty.
As to whether it would really be worth it is another matter.
But there is no doubt that it could be done.
"... to reduce the code , data size & make the code run fast"
Ideally, yes - but, in practice, reducing size and increasing speed are often in conflict. Hence most optimisers have options to optimise for speed or optimise for size.
"can you predict the execution time or the code that each compiler produces?"
No, of course you can't! It was a sarcastic comment due to the huge number of people who fall into the trap of trying to write HLL delay loops based on the (false) assumption that you can predict the execution time! See, for example, www.8052.com/.../162556
