I tried compiling using GNUARM toolchain in keil(evaluation). In the output window it shows that it has succesfully created the exe. But when I goto the path where exe is supposed to be placed, I dont find any exe there. what could be the problem?
Then please use the GNU version that we have published on this web side. We have tested all examples using this version.
There was an issue with the GCC bundle where it was missing a file. I am not sure this has been corrected yet. The file you need is: C:\ProgramFiles\GNUARM\bin\cygintl3.dll Without it builds silently fail. If you are running the Cygwin environment, the copy in the Cygwin /bin directory can be copied in. Kathy Moser
