Keil C does not support
Keil C does not support this line:
typedef const UINT32 volatile xdata *PCVX32;
it just support this way
typedef const volatile UINT32 xdata *PCVX32;
but other ANSI C compilers support both.
Is it a bug or something else?
  • "For two qualified types to be compatible, both shall have the identically qualified version
    of a compatible type; the order of type qualifiers within a list of specifiers or qualifiers
    does not affect the specified type." from ISO/IEC 9899:1999
    And I can not find more.
  • const int volatile abc; //Compiles
    const long volatile abc; //Doesn't compile
    You don't think that's a bug? Or an error?
    Neither. I consider it an insignificant inconvenience which, of course, should be fixed, but not necessarily "yesterday.
    The whole point of having an ANSI 'C' compiler is so that anyone who can write ANSI 'C' can use it. The whole thing becomes pointless if you allow compiler writers to deviate arbitrarily from that standard.
    well, if that is your opinion, let us remove DATA, XDATA etc.
    Would you consider it acceptable to have this ordering provided it were documented?
    42 int = volatile abc;
    In a low volume product, absolutely. Keil is doing a great job of making the compiling bug free and reasonably efficient, if a glitch of a certain odd sequence of parametres produce "does not compile" is that significant compared to "xxx,xxx produce the wrong result"
    I never said "forget this", just don't get your knickers in a knot becuse you have to change the sequence of two words.
    Do I expect Keil to fix this eventually, sure, but once Keil knows about it stop whining
  • TC 2.0 and HI-TECH C for 8051 are both support this:
    typedef const volatile long *pLONG;
    I think most of C compilers can accept this.
    And I just find out the matter that Keil does support it. So I share it to everyone. I don't have any other thought. Keil C is a great product and I love it. Also, nothing is perfect.
  • "You don't think that's a bug? Or an error?
    Neither. I consider it an insignificant inconvenience"
    Excellent! I shall stop calling bugs in my code 'features' and start calling them 'insignificant inconveniences' from now on.
    "The whole point of having an ANSI 'C' compiler is so that anyone who can write ANSI 'C' can use it. The whole thing becomes pointless if you allow compiler writers to deviate arbitrarily from that standard.
    well, if that is your opinion, let us remove DATA, XDATA etc."
    Don't be silly. The standard permits extensions provided they are documented. Are you unable to see the difference?
    "Would you consider it acceptable to have this ordering provided it were documented?
    In a low volume product, absolutely."
    So, you would be quite happy if you bought a 'C' compiler then discovered it actually compiled a language that wasn't 'C'?
    "just don't get your knickers in a knot becuse you have to change the sequence of two words."
    I think you're the one with his knickers in a knot!
  • Staffan:
    let me repeat from a previous post
    "Again I did not post as to the issue being mentioned, which it should, but to it being dragged out. I woukd expect Keil to check if this existed in a wider context and either document "the sequence MUST be" or allow random sequencing of keywords.".
    thus, please stop dragging it out.
  • "Staffan"
    Try again.
    "let me repeat from a previous post
    "Again I did not post as to the issue being mentioned, which it should, but to it being dragged out."
    Perhaps you should restrict your posts to technical contributions?
    "I woukd expect Keil to check if this existed in a wider context and either document "the sequence MUST be" or allow random sequencing of keywords."."
    And I have explained to you why they cannot, and would not want, to do that.
    "thus, please stop dragging it out"
    I have no desire to drag anything out. Your contribution to this thread contained errors, I corrected them. Deal with it.
  • Please state fully, you shouls post
    Your contribution to this thread in my ponion contained errors.
    That we do not agree does not make my opinion erroneous.
  • "That we do not agree does not make my opinion erroneous."
    No. That job is done by the 'C' standard.
  • oh you just can not stop.
    I NEVER said this was "correct" but I said "harping on it as a disaster is ridiculous".
    I have no doubt that Keil will eventually fix it, but to state "I can not use the compiler because I need to reverse
    to be
    typedef const volatile UINT32 xdata *PCVX32;" Is, indeed ridiculous.
    You just do not get that I am not talking about whether this is correct or not (it is not) but about it being presented as "the bug of the century" and discussed ad nauseam>
  • "I NEVER said this was "correct" but I said "harping on it as a disaster is ridiculous"."
    Nobody is 'harping on it as a disaster'. We were having a perfectly reasonable, and to some of us interesting, technical discussion until you arrived and told us to 'shut up'.
    "but to state "I can not use the compiler because I need to reverse
    to be
    typedef const volatile UINT32 xdata *PCVX32;" Is, indeed ridiculous."
    Nobody said anything remotely like that. As usual you are making stuff up to justify your position. If you feel that is not the case please quote *with context* the relevant comment.
    "You just do not get that I am not talking about whether this is correct or not (it is not)"
    What you are saying, however, is that it is perfectly ok provided Keil document it. I have repeatedly explained to you why that is not ok. You appear unable to comprehend the explanation.
    "but about it being presented as "the bug of the century" and discussed ad nauseam>"
    Nobody has presented it as 'bug of the century'.
    As you clearly have no technical contribution to make to this thread could you please stop reducing the signal to noise ratio?
  • What you are saying, however, is that it is perfectly ok provided Keil document it. I have repeatedly explained to you why that is not ok. You appear unable to comprehend the explanation.
    CORRECTION:
    What you are saying, however, is that it is perfectly ok provided Keil document it. I have repeatedly explained to you why that in my opinion is not ok. You appear unable to comprehend the explanation.
    What I am "unable to comprehend" is that your opinion is always right.
  • "What I am "unable to comprehend" is that your opinion is always right"
    It isn't my opinion. Take a look at the 'C' standard.
  • and your opinion is that to follow the standard in some obscure functionality is more important than a working compiler.
    do YOU now get it.
  • Or perhaps that following the standard in some obscure functionality is the definition of "working" in the context of a compiler.
  • "and your opinion is that to follow the standard in some obscure functionality is more important than a working compiler."
    That is not my opinion. Please stop making false attributions.
