Hi all, Is it possible to get the C51 compiler output with ELF format ?. In other words Can i extract Map file or listing file with ELF file format using c51 compiler or any other embedded system C compiler? Thanks in advance.
Looks like you're going to have to write yourself an OMF51-to-Elf converter (or pay someone else to do it for you). You can find the OMF51 spec in the downloads area of this site.
