Hi, I am using the AT89S8252 uC.I am using the internal EEPROM to store config. data.The problem now is how do I check the contents of the EEPROM during simulation. I tried x:0x0000 but my subroutine is not updating these locations... I am using assembly lang. Rgds Raj
Seems the simulation is somehow broken. As well, in debug mode: if you try to change any values in Regs list (R0, a, b etc) while Peripherals/"EEPROM Data Memory" window is opened then all checkmarks are reseted in the window. Good days!
http://www.keil.com/support/docs/2369.htm Jon
