Problem SBUF 8051
Hello everybody.
I'm french, so sorry for my english.
First, thanks for all gentlemens who will help me.
I follow a formation about programmation microcontroleur 8051's family.
First I have studied the microcontroleur himself, after I have made a lot of programs in assembleur with Keil, and no problem.
After I have learn the langage C, and I have made a lot of program on my computer for the computer, and now I try to made the same previous program that I have created in assembleur but in langage C, always with Keil, and I have a problem.
The problem is that the hyperterminal diplay :
"Serial number : 1’˜ž¤ª"
instead of display "Serial number : 111111".
The problem is when the program call the fonction VERIFTI(), the veriable unite is lost!!!!
Why ?????
Do you have an idea?
My microcontroleur is an NXP P89V51RD2BN
Please look at my program:
#include <REG51.H>
void VERIFRI()reentrant;
void VERIFTI()reentrant;
data unsigned char cent;
data unsigned char diz;
data unsigned char unite;
void Led_chenillard()
SM0=0;                          //UART en mode 1
SM1=1;                          //UART en mode 1
SM2=0;                          //Gestion multiprocesseur inactive
REN=1;                          //Reception active
TMOD=0x20;                      //Config Timer 1 en mode 2 et mode temporisateur
TH1=255;                        //56000 Bauds
TR1=1;                          //Active le timer 1
TI=1;
SBUF=0x0C;                  //Efface écran
VERIFTI();                      //Vérifie si l'envoie au PC est terminé
SBUF='S';
VERIFTI();
SBUF='e';
VERIFTI();
SBUF='r';
VERIFTI();
SBUF='i';
VERIFTI();
SBUF='a';
VERIFTI();
SBUF='lk';
VERIFTI();
SBUF=' ';
VERIFTI();
SBUF='n';
VERIFTI();
SBUF='u';
VERIFTI();
SBUF='m';
VERIFTI();
SBUF='b';
VERIFTI();
SBUF='e';
VERIFTI();
SBUF='r';
VERIFTI();
SBUF=' ';
VERIFTI();
SBUF=':';
VERIFTI();
SBUF=' ';
VERIFTI();
unite='1';
SBUF=unite;
VERIFTI();
SBUF=unite;
VERIFTI();
SBUF=unite;
VERIFTI();
SBUF=unite;
VERIFTI();
SBUF=unite;
VERIFTI();
SBUF=unite;
VERIFTI();
FIN:
goto FIN;
        DEBUT:
        if (RI==0)
        goto DEBUT;
        else
        RI=0;
        DEBUT:
        if (TI==0)
        goto DEBUT;
        else
        TI=0;
  • This is the file M51.
    Do you see an error about the memory ?
    BL51 BANKED LINKER/LOCATER V6.11                                                        09/15/2014  20:14:48  PAGE 1
    BL51 BANKED LINKER/LOCATER V6.11, INVOKED BY:
    C:\KEIL\C51\BIN\BL51.EXE Led chenillard.obj TO Led chenillard RAMSIZE (256)
    INPUT MODULES INCLUDED:
      Led chenillard.obj (LED_CHENILLARD)
    LINK MAP OF MODULE:  Led chenillard (LED_CHENILLARD)
                TYPE    BASE      LENGTH    RELOCATION   SEGMENT NAME
                * * * * * * *   D A T A   M E M O R Y   * * * * * * *
                REG     0000H     0008H     ABSOLUTE     "REG BANK 0"
                DATA    0008H     0003H     UNIT         ?DT?LED_CHENILLARD?LED_CHENILLARD
                * * * * * * *   C O D E   M E M O R Y   * * * * * * *
                CODE    0000H     00A7H     UNIT         ?PR?LED_CHENILLARD?LED_CHENILLARD
                CODE    00A7H     0009H     UNIT         ?PR?VERIFTI?LED_CHENILLARD
                CODE    00B0H     0006H     UNIT         ?PR?VERIFRI?LED_CHENILLARD
    SYMBOL TABLE OF MODULE:  Led chenillard (LED_CHENILLARD)
      VALUE           TYPE          NAME
      -------         MODULE        LED_CHENILLARD
      C:0000H         SEGMENT       ?PR?LED_CHENILLARD?LED_CHENILLARD
      D:0008H         SEGMENT       ?DT?LED_CHENILLARD?LED_CHENILLARD
      C:00B0H         SEGMENT       ?PR?VERIFRI?LED_CHENILLARD
      C:00A7H         SEGMENT       ?PR?VERIFTI?LED_CHENILLARD
      C:0000H         PUBLIC        LED_CHENILLARD
      C:00B0H         PUBLIC        VERIFRI
      C:00AAH         PUBLIC        VERIFTI
      C:00A5H         SYMBOL        ?C0001
      C:00B0H         SYMBOL        ?C0004
      C:00B3H         SYMBOL        ?C0005
      C:00AAH         SYMBOL        ?C0007
      C:00ADH         SYMBOL        ?C0008
      D:0008H         SYMBOL        ?LED_CHENILLARD?BYTE
      B:00D0H.6       SYMBOL        AC
      D:00E0H         SYMBOL        ACC
      D:00F0H         SYMBOL        B
      D:000AH         SYMBOL        CENT?042
      B:00D0H.7       SYMBOL        CY
      D:0009H         SYMBOL        DIZ?041
      D:0083H         SYMBOL        DPH
      D:0082H         SYMBOL        DPL
      B:00A0H.0       SYMBOL        E
      B:00A8H.7       SYMBOL        EA
      B:00A8H.4       SYMBOL        ES
      B:00A8H.1       SYMBOL        ET0
      B:00A8H.3       SYMBOL        ET1
      B:00A8H.0       SYMBOL        EX0
    BL51 BANKED LINKER/LOCATER V6.11                                                      09/15/2014  20:14:48  PAGE 2
      B:00A8H.2       SYMBOL        EX1
      B:00D0H.5       SYMBOL        F0
      D:00B1H         SYMBOL        IAP
      D:00A8H         SYMBOL        IE
      B:0088H.1       SYMBOL        IE0
      B:0088H.3       SYMBOL        IE1
      B:00B0H.2       SYMBOL        INT0
      B:00B0H.3       SYMBOL        INT1
      D:00B8H         SYMBOL        IP
      B:0088H.0       SYMBOL        IT0
      B:0088H.2       SYMBOL        IT1
      C:00A7H         SYMBOL        L?0010
      B:00D0H.2       SYMBOL        OV
      B:00D0H.0       SYMBOL        P
      D:0080H         SYMBOL        P0
      B:0080H.0       SYMBOL        P0_0
      B:0080H.1       SYMBOL        P0_1
      B:0080H.2       SYMBOL        P0_2
      B:0080H.3       SYMBOL        P0_3
      B:0080H.4       SYMBOL        P0_4
      B:0080H.5       SYMBOL        P0_5
      B:0080H.6       SYMBOL        P0_6
      B:0080H.7       SYMBOL        P0_7
      D:0090H         SYMBOL        P1
      B:0090H.0       SYMBOL        P1_0
      B:0090H.1       SYMBOL        P1_1
      B:0090H.2       SYMBOL        P1_2
      B:0090H.3       SYMBOL        P1_3
      B:0090H.4       SYMBOL        P1_4
      B:0090H.5       SYMBOL        P1_5
      B:0090H.6       SYMBOL        P1_6
      B:0090H.7       SYMBOL        P1_7
      D:00A0H         SYMBOL        P2
      B:00A0H.3       SYMBOL        P2_3
      B:00A0H.4       SYMBOL        P2_4
      B:00A0H.5       SYMBOL        P2_5
      B:00A0H.6       SYMBOL        P2_6
      B:00A0H.7       SYMBOL        P2_7
      D:00B0H         SYMBOL        P3
      B:00B0H.0       SYMBOL        P3_0
      B:00B0H.1       SYMBOL        P3_1
      B:00B0H.2       SYMBOL        P3_2
      B:00B0H.3       SYMBOL        P3_3
      B:00B0H.4       SYMBOL        P3_4
      B:00B0H.5       SYMBOL        P3_5
      B:00B0H.6       SYMBOL        P3_6
      B:00B0H.7       SYMBOL        P3_7
      D:0087H         SYMBOL        PCON
      B:00B8H.4       SYMBOL        PS
      D:00D0H         SYMBOL        PSW
      B:00B8H.1       SYMBOL        PT0
      B:00B8H.3       SYMBOL        PT1
      B:00B8H.0       SYMBOL        PX0
      B:00B8H.2       SYMBOL        PX1
      B:0098H.2       SYMBOL        RB8
      B:00B0H.7       SYMBOL        RD
      B:0098H.4       SYMBOL        REN
    BL51 BANKED LINKER/LOCATER V6.11                                                      09/15/2014  20:14:48  PAGE 3
      B:0098H.0       SYMBOL        RI
      B:00A0H.2       SYMBOL        RS
      B:00D0H.3       SYMBOL        RS0
      B:00D0H.4       SYMBOL        RS1
      B:00A0H.1       SYMBOL        RW
      B:00B0H.0       SYMBOL        RXD
      D:0099H         SYMBOL        SBUF
      D:0098H         SYMBOL        SCON
      B:0098H.7       SYMBOL        SM0
      B:0098H.6       SYMBOL        SM1
      B:0098H.5       SYMBOL        SM2
      D:0081H         SYMBOL        SP
      B:00B0H.4       SYMBOL        T0
      B:00B0H.5       SYMBOL        T1
      B:0098H.3       SYMBOL        TB8
      D:0088H         SYMBOL        TCON
      B:0088H.5       SYMBOL        TF0
      B:0088H.7       SYMBOL        TF1
      D:008CH         SYMBOL        TH0
      D:008DH         SYMBOL        TH1
      B:0098H.1       SYMBOL        TI
      D:008AH         SYMBOL        TL0
      D:008BH         SYMBOL        TL1
      D:0089H         SYMBOL        TMOD
      B:0088H.4       SYMBOL        TR0
      B:0088H.6       SYMBOL        TR1
      B:00B0H.1       SYMBOL        TXD
      D:0008H         SYMBOL        UNITE?040
      B:00B0H.6       SYMBOL        WR
      C:0000H         LINE#         143
      C:0002H         LINE#         146
      C:0004H         LINE#         149
      C:0006H         LINE#         152
      C:0008H         LINE#         156
      C:000BH         LINE#         159
      C:00ADH         LINE#         397
      C:00AFH         LINE#         399
      -------         ENDMOD        LED_CHENILLARD
    Program Size: data=11.0 xdata=0 code=182
    LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
  • well now we see that there is more than what you show involved. do a GLOBAL search on unite and fin the other place that play with it
  • The variable unite is use only at line :
    but I note that there is a ?040. Why ?
    It's so easy in assembleur why is it so difficult in C ? However, the C language is a high level language.
    The problem, I think, is that the variable "unite" is not stock at the good place, and I think that there is, somewhere in Keil, a place to define this, because in assembleur we define this emplacement, for example (MOV 33h, #01Fh), bot not in C, and I don't know how Keil define this automatically.
    When we create a software on a PC, windows define automatically the place where variables are stock in the RAM, but maybe with microcontroleur it works diferently.
    Are you OK with me ?
  • I solved part of my problem.
    Instead of declaring my variables at the begining of the program, I declare it in the fonction.
    Before :
    #include <REG51.H>
    void VERIFRI();
    void VERIFTI();
    And now :
    #include <REG51.H>
    void verifri();
    void verifti();
    void led_chenillard()
    TI=1;
    verifti();                      //Vérifie si l'envoie au PC est terminé
    SBUF='S';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF='i';
    verifti();
    SBUF='a';
    verifti();
    SBUF='l';
    verifti();
    SBUF=' ';
    verifti();
    SBUF='n';
    verifti();
    SBUF='u';
    verifti();
    SBUF='m';
    verifti();
    SBUF='b';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF=' ';
    verifti();
    SBUF=':';
    verifti();
    SBUF=' ';
    verifti();
    unite='1';
    P2='1';
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    P1=unite;
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    while (1);
    void verifri()
            while (RI==0);
            RI=0;
    void verifti()
            while (TI==0);
            TI=0;
    So, with this program the hyperterminal of the PC display "Serial number : 111111".
    BUT now if I swap the variables at the time of the statement, it does not work anymore. The PC display "Serial number : çiEEöf.
    #include <REG51.H>
    void verifri();
    void verifti();
    data unsigned char unite;             //unite changed place
    Why ????
  • because whatever writes over, now overwrites 'cent'
    you DO have a 'wild' write to the position that is unite/cent FIND IT.
    is there somewhere in the rest of your code a write to an absolute address?
  • Thank you very much for your dedication.
    I don't understand "you DO have a 'wild' write to the position that is unite/cent FIND IT."
    is there somewhere in the rest of your code a write to an absolute address? :
    All of my code is here. As you can see I declare 3 variables at the beginig o "unite, "diz", and "cent", but actually only "unite" is used. When I have solved my problem I can go further, and use the other variable.
    My complete code is :
    #include <REG51.H>
    void verifri();
    void verifti();
    TI=1;
    SBUF='S';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF='i';
    verifti();
    SBUF='a';
    verifti();
    SBUF='l';
    verifti();
    SBUF=' ';
    verifti();
    SBUF='n';
    verifti();
    SBUF='u';
    verifti();
    SBUF='m';
    verifti();
    SBUF='b';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF=' ';
    verifti();
    SBUF=':';
    verifti();
    SBUF=' ';
    verifti();
    unite='1';
    P2='1';
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    P1=unite;
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    while (1);
    void verifri()
            while (RI==0);
            RI=0;
    void verifti()
            while (TI==0);
            TI=0;
  • Your complete code???
    Where is main()?
  • Ok, I have changed void led_chenillard() for void main(), but the problem is the same, and in addition I have a new warning :
    Warning L1 : unresolved external symbol
    Symbol : ?C_STARTUP
    Module : Led chenillard.obj (LED_CHENILLARD)
    #include <REG51.H>
    void verifri();
    void verifti();
    void main()
    TI=1;
    SBUF='S';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF='i';
    verifti();
    SBUF='a';
    verifti();
    SBUF='l';
    verifti();
    SBUF=' ';
    verifti();
    SBUF='n';
    verifti();
    SBUF='u';
    verifti();
    SBUF='m';
    verifti();
    SBUF='b';
    verifti();
    SBUF='e';
    verifti();
    SBUF='r';
    verifti();
    SBUF=' ';
    verifti();
    SBUF=':';
    verifti();
    SBUF=' ';
    verifti();
    unite='1';
    P2='1';
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    P1=unite;
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    SBUF=unite;
    verifti();
    while (1);
    void verifri()
            while (RI==0);
            RI=0;
    void verifti()
            while (TI==0);
            TI=0;
  • Sorry - I've lost track of what the actual problem is!
    Symbol : ?C_STARTUP
    You're not using the SRC directive (or GUI equivalent) to convert all your 'C' to assembly, are you...?
    www.keil.com/.../search.asp
  • You are probably right. Thanks you for your help.
