SPI communication between two microcontrollers
Hello everyone,
I am trying to make communication between an STM32F3 microcontroller and a custom board baser on PIC microcontroller using SPI protocol.
The STM32F3 acts as a Slave and the custom board as a Master. The clock is set to 10 MHz. I’m using NSS hardware, and getting EXTI once CS gets low in NSS pin. The CPOL and CPHA are compatible between the two boards.
I am using Interrupt base communication in the Slave side.
The application consists of:
1) The Master sends a command to the Slave, then a data of 4 bytes : This part works fine
2) The Master sends continuously different commands, The Slave process the command, then sends its proper data (4 bytes) depending on the received command. The Updating frequency sends by the Master is about 20 KHz.
I have a problem with the second case, in fact, when the Master sends a command, let’s say 0x01, the Slave process this address and then sends back a frame let’s say 0x410547AF.
In the MISO line the frame is shifted, c.a.d (0x47, 0xAF, 0x41, 0x05, 0x05) instead of (0xXX, 0x41,0x05, 0x47, 0xAF), because the first byte corresponds to the byte when the address is received.
I also used the debug mode to view the SR register and I can see that the FIFO transmission level is always at 2, that explains why the frame is shifted by 2 bytes. But I can’t find a solution to my problem, do you have an idea what would be the problem please?
If you want some code sample, I can post it.
I hope that my problem is clear.
Thanks in advance
Best regards
  • Thank you sirs Hans-Bernhard and Per for your precious explanations.
    I tried to use the hardware slave select pin in the Slave side but i didn't succeed. I have read many posts about the NSS deficiencies in the STM32.
    Please would you have some details how to manage this signal?
    Thanks in advance,
    Best regards
