help with arm
Hello friends, I need your help
have time programming code for 8051 (c51) in keil and have no problem
but now I would like to start with arm, specifically with LPC2138 and I want to convert the code I show is written for 8051
but not to start. All I know is how to define ports and little else.
I swear I've tried but have not succeeded.
the code is for a led matrix display and Works fine
please can help me?
thank you very much
carlos
//crystal is 22-24MHz
//was made for Keil compiler
#include <reg51.h>
#define BAUDRATE 9600
sbit Cclock=P1^1;
sbit Clatch=P1^0;
sbit Cdata=P3^7;
sbit Row1=P1^2;
sbit Row2=P1^3;
sbit Row3=P1^4;
sbit Row4=P1^5;
sbit Row5=P1^6;
sbit Row6=P1^7;
sbit Row7=P3^2;
sbit Row8=P3^3;
unsigned int shift_delay;
unsigned char code font[96][16] =
{0x00, 0x1f, 0x11, 0x11, 0x00}, // {0x10, 0x08, 0x04, 0x02, 0x01}, // {0x00, 0x11, 0x11, 0x1f, 0x00}, // {0x04, 0x08, 0x10, 0x08, 0x04}, // {0x01, 0x01, 0x01, 0x01, 0x01}, // {0x00, 0x00, 0x10, 0x08, 0x00}, // {0x12, 0x15, 0x15, 0x15, 0x0f}, //a {0x1f, 0x09, 0x09, 0x09, 0x06}, //b {0x0e, 0x11, 0x11, 0x11, 0x0a}, //c {0x06, 0x09, 0x09, 0x09, 0x1f}, //d {0x0e, 0x15, 0x15, 0x15, 0x0d}, //e {0x0f, 0x14, 0x14, 0x10, 0x10}, //f {0x09, 0x15, 0x15, 0x15, 0x0e}, //g {0x1f, 0x08, 0x08, 0x08, 0x07}, //h {0x00, 0x00, 0x17, 0x00, 0x00}, //i {0x01, 0x01, 0x01, 0x01, 0x1e}, //j {0x1f, 0x04, 0x04, 0x0a, 0x11}, //k {0x1e, 0x01, 0x01, 0x01, 0x01}, //l {0x0f, 0x10, 0x0f, 0x10, 0x0f}, //m {0x1f, 0x10, 0x10, 0x10, 0x0f}, //n {0x0e, 0x11, 0x11, 0x11, 0x0e}, //o {0x1f, 0x12, 0x12, 0x12, 0x0c}, //p {0x0c, 0x12, 0x12, 0x12, 0x1f}, //q {0x1f, 0x08, 0x10, 0x10, 0x08}, //r {0x09, 0x15, 0x15, 0x15, 0x12}, //s {0x1e, 0x09, 0x09, 0x01, 0x02}, //t {0x1e, 0x01, 0x01, 0x02, 0x1f}, //u {0x18, 0x06, 0x01, 0x06, 0x18}, //v {0x1e, 0x01, 0x1e, 0x01, 0x1e}, //w {0x1b, 0x04, 0x04, 0x04, 0x1b}, //x {0x19, 0x05, 0x05, 0x05, 0x1e}, //y {0x11, 0x13, 0x15, 0x19, 0x11}, //z {0x00, 0x04, 0x0e, 0x11, 0x00}, // {0x00, 0x00, 0x1f, 0x00, 0x00}, // {0x00, 0x11, 0x0e, 0x04, 0x00}, // {0x08, 0x10, 0x08, 0x04, 0x08}, // {0x00, 0x00, 0x00, 0x00, 0x00} //
unsigned char column[41]=
{ 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
}; //display memory, cleared before used.
void delayms(unsigned int ms) //just about 1ms
{ unsigned int n; unsigned int i; for (n=0; n<ms; n++) { for (i=0; i<200; i++); }
void init_timer(void)//config timer for 6.7ms
{ TMOD=0x01; TH0=0xf8; TL0=0x00; TR0=1; ET0=1; EA=1;
void Timer0 (void) interrupt 1 //using 2
{ unsigned int index; unsigned int i,tmp1; unsigned char code rowtable[]={0,1,2,4,8,16,32,64,128}; TH0=0xf8; TL0=0x00; ET0=0;
Row8=1; Row7=1; Row6=1; Row5=1; Row4=1; Row3=1; Row2=1; Row1=1; index++; if (index>8) index=1;
//column tmp1=rowtable[index]; for (i=1; i<41; i++) { Cdata=!(column[i] & tmp1); Cclock=0; Cclock=1; } //row Clatch=0; Clatch=1; switch (index) { case 1: Row1=0; break; case 2: Row2=0; break; case 3: Row3=0; break; case 4: Row4=0; break; case 5: Row5=0; break; case 6: Row6=0; break; case 7: Row7=0; break; case 8: Row8=0; break;
} ET0=1;
void LED_put_byte(unsigned int inp)
{ unsigned char i; for (i=1;i<41;i++) column[i]=column[i+1]; column[40]=inp;
void LED_puts(unsigned char *lcd_string)
{ unsigned char i,tmp_chr; while (*lcd_string) { tmp_chr=*lcd_string; for (i=0;i<6;i++) { LED_put_byte(font[tmp_chr-32][i]); delayms(shift_delay); } LED_put_byte(0); //space between character delayms(shift_delay); lcd_string++; }
void main()
{ unsigned char m[40], i; TMOD=0x20; // Timer 1, mode-2 (8-bit auto reload) TH1=0xFA; //9600 baud rate SCON=0x50; TR1=1; //start timer 1
/* read 10 bytes or till enter key */ for (i = 0; i < 240; i++) { while (RI == 0); //wait to receive data if (SBUF == '\r') break; m[i] = SBUF; // save value of data RI = 0;
} m[i] = '\0';
init_timer(); shift_delay=40; //bigger = slower shift while(1) {
// display m LED_puts(m); }
