SSP vs SPI - interrupt code not compatible
Hey,
Thinking that the SSP and SPI interfaces are the same, I wrote the code for SSP slavemode interrupt.
But then found out that there is a difference. The CS(SSEL) line in SPI remains low for whole frame transfer, in SSP but it toggles after each frame (a frame = 4-16bits _configurable_) in SSP. (SPI frame can be of 'n' no of bytes)
So at the master, i modified the CS to act as GPIO and toggle the line after every byte transfer.
Now the problem is that if i process interrupt after receiving of each data byte the code generates an os_error. Hence (referring an example code) i had to implement the data transfer in a while loop as in the code below:
while( (SSPx->SR & SSP_SR_RNE) || (SSPx->SR & SSP_SR_TFE) || (dataCfg->tx_cnt != dataCfg->length))
        tmp = SSP_ReceiveData(SSPx);
        if(tmp == SPI_SOF)
                dataCfg->rx_cnt = 0;
                dataCfg->tx_cnt = 0;
                dataCfg->status = SPI_STATUS_SOF;
        if(dataCfg->tx_data == NULL)
                SSP_SendData(SSPx, 0xFF);
                dataCfg->tx_cnt++;
        else
                SSP_SendData(SSPx, (*(uint8_t *)((uint32_t)dataCfg->tx_data + dataCfg->tx_cnt)));
                dataCfg->tx_cnt++;
        // Store data to destination
        //if (dataCfg->rx_data != NULL)
                *(uint8_t *)((uint32_t)dataCfg->rx_data + dataCfg->rx_cnt) = (uint8_t) tmp;
                        dataCfg->rx_cnt++;
        // Check error
        if ((stat = SSPx->RIS) & SSP_RIS_ROR)
                // save status and return
                dataCfg->status = stat | SSP_STAT_ERROR;
                return;
os_error = 2, which indicates that the interrupt occurance is too fast.
CPOL = 0, CPHA = 1.
performing the data transfer in while loop, causes loss of synchronization. Cant figure out how to solve this.
The master clock frequency = 250KHz. Master is a microchip IC (whose code worked well with SPI protocol of LPC1768).
  • Thank you for clearing the air about FIFO.
    I have implemented the ISR for SSP.
    The protocol is a bit complicated. The slave sends the answer for the previous question (asked in previous SSEL cycle) that the master had asked, in the current SSEL cycle. If there was any communication failure, it is indicated by the NACK bytes transmission instead of the answer.
  • Then you could have the pin you connected slave select to generate a pin-change interrupt - or an external interrupt if the relevant pin happens to have EINTx support.
    So SSP interrupt could just send out data and retrieve data (multiple words handled in each interrupt thanks to FIFO), interfacing with suitably large ring buffers. And the pin-change interrupt creates an event to report "transer done: process input and prepare new output".
