Hi I want to draw graphs of position of 2-phased QEI versus time. so I want to capture QEI position every time period. time gap between to position pulses is at least 7.2 microseconds. I think I have to choose one of these methods:
1-send position to USB during time overflow interrupt(TIM_INT)
2-send content of the timer when the situation changes. (I don't know if it is possible to sense the changes as an interrupt?)
I think there are some restrictions due to interrupt latancy. so what is the highest resolution for my system. and which method is better? How can I define interrupt for 2nd method? can i send data to buffer and send batch buffer to USB? Is it help me Reduce interrupt latancy effects? HOW? Please Help me Best Regards
Hi Dear Erik It seems that Tsuneo rarely comes here! due to low rate of USB functions, i must buffer data and send them in batch. And in the end, i should reset the timer. so how can i buffer the data? should i use an auxiliary register? how can i detect that number of bytes written in QEITIME(or auxilary Buffer) is 512? should i pend the interrupt to send the data(buffer) to USB? cause the usb functions are too slow?
Amir hejazi1365[at]gmail[dot]com Best regards
I got really disappointed!! Any body couldn't help me with the buffer?
thanks Amir hejazi1365[at]gmail[dot]com
not trying to 'disappoint' you but I can't simply because I have never worked with this specific issue (have no idea what QEITIME is) how can i detect that number of bytes written in QEITIME(or auxilary Buffer) is 512? for the usual buffer which is written by address[index] 'index', of course will hol;d the count.
Maybe you would care to expand why you feel "really disappointed".
It isn't like you are paying to get support from this web forum.
The only way other Keil users can help you is by spending their time retrieving the available information and read it. The big question is why other people should invest their own, private, time to do that when they don't have any incentive to do so. That time could instead be spent listening to music, walking the dog or maybe earn $$$ by developing applications.
You, on the other hand, should have specific incentives to spend time with the available sample source code, application notes and processor user manual.
>Aren't you a funny guy?
I don't care you are an active user or a KEIL Employee. but is it your amusement to visit this forum to write such sentences?
Some people usually share their information & knowledge through forum and some other ask (or even beg) other people to help them. I didn't forced Mr Tsuneo & Mr Erik to answer me! Both of them kindly answered some of my questions. And speaking about "disappointing" won't oblige them to answer and I think it does not contain any insults.
Amir Hejazi.1365@gmail.com
What amusement do you find in the sentence "Maybe you would care to expand why you feel 'really disappointed'"?
Did you _really_ read what I wrote?
"Some people usually share their information & knowledge through forum and some other ask (or even beg) other people to help them."
Share information requires that the helper already know the answer. If no one who reads your question knows the answer, then no one will be able to share that answer too, unless they invest own time to figure out the answer. And here is where you _do_ have to care about people just being other users of the Keil tools like your self, or if this is a payed support service where people are payed to supply help.
By the way - all your posting of email addresses implies that you want answers sent directly to you instead of having the answers posted on this forum. Private answers do have the big disadvantage that they can't be picked up by Google. So they would not help anyone else.
>In the QEI ISR, the timer value is written to a buffer of 1024 bytes.[Tsuneo]
When the buffer holds 512 bytes (sector size) or more, one sector of data is written to the USB drive.
about one of my questions "the helper already know the answer." and i want to know whats the name of the buffer. is it direct or indirrect? but no body answered me.
I said if they don't want to "share their information" for free and want to "earn $$$", I respectfully write my Email, to send me the price, Because I really need this buffer.
Amir
"about one of my questions "the helper already know the answer.""
Sorry, but you need to read more carefully.
The text you mention said:
In the QEI ISR, the timer value is written to a buffer of 1024 bytes. When the buffer holds 512 bytes (sector size) or more, one sector of data is written to the USB drive.
If you write a QEI ISR, then it would be _you_ who knows the name of the buffer _you_ place the values in. And it would be _you_ who knows when you have 512 bytes of data in that buffer, so _you_ would know when you have enough to write one sector to the USB drive.
If _you_ haven't written the QEI ISR, then it would still be _you_ who should locate the source of that ISR and look what buffer the data is stored in.
Do you even know if there exists any QEI ISR?
Thanks So, I must read the GPDMA session from datasheet. and define a buffer. i'll working on it. and then ask the questions about it.
Best Regards Amir
When using any peripherial that has the hardware support for it, you may be able to poll the device for data. Or configure the device to issue an interrupt for each data getting available. Or configure the device to hand off data to a DMA channel. This may be an SPI device, an UART, or maybe an ADC - the concept is still the same.
So if this quadrature device supports DMA, then you need to configure one DMA channel to take the quadrature device as data source, and a buffer as data destination. The DMA channel can then generate interrupts to let you take care of received data and potentially supply new buffers to use. For DMA channels that supports it, it is often nice to have a buffer that is twice as large as the block size you want. So the DMA channel can interrupt when the buffer is half-full. Then you have ample time to take care of the already received data while the DMA channel continues to fill the other half of the buffer. And the ISR can tell the DMA what to do when the second half of the buffer gets full - i.e. that the DMA channel should restart from the beginning of the buffer again. So you basically double-buffer the transfer with a 2*n-sized buffer.
If you don't have too high data rates, it is possible to ignore any DMA transfers and instead have one interrupt/sample. And have the ISR pick up a single value and put in a buffer. This is ok as long as the ISR doesn't consume too much time, and the ISR is guaranteed to pick up a value before the device have produced the next value.
So Tsuneo Chinzei is talking about a concept, while leaving it to you to flesh out actual code to fulfill this concept. Note also that he wrote:
As of QEI unit of LPC17xx, an ENCLK_Int interrupt occurs at the every transition of the encoder. In this ISR, your firmware reads out a timer value, which runs freely, to know the interval of the every transition. Cortex-M3 NVIC has fixed interrupt latency of 12 cycle. You may get exact interval with this method.
That indicates the he isn't talking about any DMA transfers, but about the ISR handling individual samples. So that would obviously mean that _you_ would be the one who decides the name of the buffer, and you who decides how to keep track of amount of data in the buffer.
So no way at all that anyone else can tell you the names that _you_ would decide to use when _you_ implement that ISR. So the reason no one gives you the answer to your questions is that it isn't possible for anyone to answer them. It's on your table to decide.
OK the datasheet says:
GPDMA supports the SSP, I2S, UART, A/D Converter, and D/A Converter peripherals. DMA can also be triggered by a timer match condition. Memory-to-memory transfers and transfers to or from GPIO are also supported.
and it appears that DMA doesn't support QEI. so I must define a normal vector as a buffer, am I right? and due to the low rate of data changes(least than 1 MHz) the ISR should "pick up a single value and put in a buffer."
I am a beginner in ARM and embedded systems, and need to learn too much about architecture. ;-)
thanks Amir
Are you sure you are working on this?
I did a very quick browse of the GPDMA information in the processor user manual - it doesn't list the quadrature encoder among supported sources.
Which means you basically got all required information already in Tsuneo's earlier posts, if you had decided to read what he wrote and compare with the capabilities of your processor.
Yes - you need to take care of the results one-by-one in an ISR. And invent a buffer to store the result in.
"i'll working on it." is different with "i'm working on it"
Because I am working on some thing in Parallel. and as I said before, due to my weak Architecture knowledge, I had no imagination about DMA. If you did not tell me that DMA must supports the QEI, I would keep on concentrating on it. Because I thought that I can consider the QEITIME register as a part of Memory, and use "Memory-to-memory transfer" feature to buffer Data. but as _you_ said, it is not suitable to use DMA. and I think I should use a vector as buffer.
thanks
Correct - "I'll working" isn't a correct sentence. "I am working" - doing now. "I have been working" - have already done it "I will be working" - something happening in the future "I will work" - something happening in the future "I am going to be working" - basically just more complicated construct
But that still doesn't change the fact that you - after having received all required information - comes back after a number of days and tells us how disappointed you are that no one is giving you the required answers. And then, when asked about your email address, specifically say you put up the address to let people quote a price to supply you with the information no one can really give you since you first need to write that ISR before it will be known what name you selected for that buffer.
That implies that you haven't been working on the problem, but have instead been assuming someone else should supply you with a solution. Enough so, that you are getting a bit irritated that people haven't stepped in and posted the solution.
The traditional route is that people work first. Then post questions about specific issues when they are stuck. Such a route would have made it obvious to you that you didn't have any open question about any buffer name more than a week ago.
Not only that. You earlier did write "I have written below codes [...]" and posted code containing:
*UserBuffer=LPC_QEI->QEITIME;
So it would then be up to you to know exactly where that "UserBuffer" comes from.
