Hello, I could successfully interfaced GSM modem to PC. now i want to interface the same modem to AT89C51. so can any one please suggest any site where i will get a sample of a program?? actually i referred some sites but i got all C programs and i want to do programming in assembly. because rest of my program is in assembly.so if available please suggest me some sites where i will find programs in "assembly language"
also, In many circuits i saw use of LCD to display responses from modem. but in my case i don't want to use LCD for this purpose. my doubt is In any case we have to input those responses from GSM modem to microcontroller,otherwise communication won't be possible right? please correct me if i am wrong.
thank you :)
And my point is that there is nothing new, novel, or special in what you are doing.
It is just standard AT Command processing.
It has been done countless times over many decades.
There is no shortage of examples!
www.lmgtfy.com
If a modem command is expected to respond with an OK - don't you think you should consider implementing a send_at() command that sends a command and waits for the "OK" or a timeout or an error?
Then you send the commands one by one and check if you got your "OK" or not.
It is a standard dialogue. If you talk with someone and ask a question, you normally then give them time to respond before you continue to talk. Same with a modem. And just as when you ask a question, you might not get the answer you expect. So you may have to change your line of discussion based on the received answer.
If you see a "RING", it obviously will not go well to think you can lift the hook and dial a number - lifting the hook will accept the incoming call instead of allowing you to make an outgoing call. So besides ok/error responses, some unsolicited messages might be needed to be properly handled too - that was a reason why I suggest a state machine for handling the modem interaction.
Hello sir, Thank you for your co-operation. I have edited my code
here is the edited code:
ORG 0000H MOV TMOD,#20H //TIMER 1, MODE 2 MOV TH1,#-3 //9600 BAUD RATE MOV SCON,#50H //8 BIT, 1 STOP, EN ENABLED SETB TR1 MOV DPTR,#MSG1 ACALL H1 ACALL DELAY MOV DPTR,#MSG2 ACALL H1 ACALL DELAY MOV DPTR,#MSG3 ACALL H1 ACALL DELAY MOV DPTR,#MSG4 ACALL H1 ACALL DELAY MOV DPTR,#MSG5 ACALL H1 ACALL DELAY STAY: SJAMP STAY H1: CLR A MOVC A,@A+DPTR JZ B1 ACALL SEND INC DPTR SJMP H1 B1: RET SEND: MOV SBUF,A H2: JNB TI,H2 CLR TI RET DELAY: MOV R3,#50H HERE2: MOV R4,#50H HERE: DJNZ R4,HERE DJNZ R3,HERE2 RET ORG 300H MSG1: DB "AT",0DH DB 0H MSG2: DB "AT+CMGF=1",0DH DB 0H MSG3: DB "ATE=0",0DH DB 0H MSG4: DB "AT+CMGS=",'"8149111111"',0DH DB 0H MSG5: DB "TEXT",0X1A DB 0H END
now is it correct??
But your edited code still don't care about modem responses - all you have is a stupid delay that don't take into account how long time the modem needs. Or if the modem accepts or rejects the command.
So exactly what did you think your improvement was, when you asked "now is it correct??"
No, it isn't. And the only way you could fail to know that already is if you not even bothered to compile it before showing it here.
Would make far more sense to attempt assembly of that code. A compiler is likely to throw up a lot of errors, what with it not being a high level language.
Actully previously i was confused in use of DPTR.
How to Synchronize those commands and routines sir?? Actually i had referred many C programs in which they hadn't considered these responses and i don't know why. :(
Please tell me how to program the same?
I had compiled my program in keil uversion 3
I got 0 errors and 0 warnigs..
So maybe you should check what C programs you have found. Bad student code is bad student code, even if uploaded and available on the net.
Whenever you do google and find some code, you must try to make some educated guess if the person who wrote the code really is skilled enough that you want to read and learn from the code. Or if it might have been a student with the view "it was hard for me to write, so this must be rocket science - I better share".
Have you really made sure you used good Google search terms when searching for code? Note that for C communication with a modem, 8051 is not a good search term - it will just limit the number of possible hits. The interaction with the modem looks the same whatever processor you use. It is only the low level code for sending/receiving individual characters that differs between hardware environments. So info about smart serial communication can include 8051 as search term, since it is interesting to specifically look at examples that uses interrupts or polling when accessing an 8051 UART.
okay.. thank you for spending your time for me..
Can you please guide me to program that synchronization part?? Please..
If I have two choices - spending time teaching you how to make the interaction with the modem a dialog (despite that information already available on the net) or spend the same time earning money by developing commercial solutions - which alternative do you think I prefer?
Developing - doesn't matter if doing it as a hobbyist, student or professionally - requires you to be comfortable with searching for, and analyzing information. It may be requirements specifications that must be broken down into pieces and have any goofs or missed issues located. It may be scanning the net for current state-of-the-art or trying to figure out if there may be competing patents. But whatever level you are on, you just _need_ to be comfortable using the web search engines. And make a quality-guestimate for all found information. Other people can't do it for you.
RE: Who woke up the amateurs? as seen aboe they came out in droves
It's an unfortunate state ;)
