#include<reg51.h> void boud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { boud_rate(); unsigned char rx_data; for(;;) { rx_data = serial_receive(); switch(rx_data) { // case '1': open_door(); case 0067892341 : open_door(); break; // case '9': open_door(); case 0045780034 : open_door(); break; default: dont_open(); } proper_delay(); } }
errors
'rx_data':undefined identifier illigal octal digit
please tell me how to overcum these errors
You are continuing your programming by introduction of random changes. Genetic programming really is not a fast route.
You have arrays of type unsigned char - what did the manual say that strcmp() expects? So why did you make your decision to use unsigned char arrays?
You still don't process received data character-by-character, to get a $ followed by 10 digits before you terminate the string with a '\0' and start comparing with your reference keys.
And you have zero synchronization between your interrupt handler and your main loop.
Your programs are never even close to function, because you are constantly ignoring the information you get about existing errors in the code. Moving the code will not remove the bugs in the code. Or will not automagically include extra code lines to perform the actions that your code do not make.
Why are you even using an interrupt handler for serial communication, if you haven't implemented any buffered solution so that the interrupt handler can operate independently of the main loop? You take the disadvantages with an interrupt-based solution while gaining none of the advantages...
When will you finally consider to spend some time with a good book about C programming?
newsflash today pradeepkumar read a C book today pradeepkumar followed the suggestions in this thread in other news: today hell froze over
It has happened before, you know. www.podcastingnews.com/.../hell-freezes-over-350.jpg
ya, for sure I will study c textbook. Will you suggest me any good c book to study..?(online/which is available on internet) I will study for some days, i will correct the mistakes and then i will post my code.
Suggestions here: blog.antronics.co.uk/.../
"online/which is available on internet"
Why not go to a real bookstore, and buy a real book?
Have you considered taking a class?
#include <reg51.h> #include <string.h> #include "_LCD_R8C.c" #define INPUT_LENGTH 12 #define ACCEPTABLE_INPUT_COUNT 2 char input[INPUT_LENGTH]; /* The input from the serial port */ int input_pos = 0; /* Current position to write in the input buffer */ int input_done = 0; /* 0 = not done yet, 1 = all input read */ void serial_int (void) interrupt 4 { if (!input_done && RI == 1) { /* Put the input at next position in the input buffer */ /* Then increase the position */ input[input_pos++] = SBUF; // lcd_command(0xC6); // lcd_print_b(SBUF); // lcd_command(0xC0); // lcd_print_b(input[input_pos]); RI = 0; SBUF=0; /* Check if we have received all input yet */ if (input_pos >= INPUT_LENGTH) input_done = 1; } } int main() { int i; /* Array of data that this programs thinks is acceptable */ char acceptable_inputs[ACCEPTABLE_INPUT_COUNT][INPUT_LENGTH] = { "$0016221826", "$0123456789" }; int acceptable_found = 0; /* Acceptable input found? */ /* Initialization */ lcd_init(); lcd_clear(); SCON = 0x50; TMOD = 0x20; TH1 = 0xFD; ET0 = 0; TR1 = 1; RI = 1; ES = 1; EA = 1; /* Wait until we have received all input */ // while (!input_done) // ; /* Do nothing */ /* Check the received input for something we accept */ for (i = 0; i < ACCEPTABLE_INPUT_COUNT; i++) { if (memcmp(acceptable_inputs[i], input, INPUT_LENGTH) == 0) { /* Yes, the data received is acceptable */ acceptable_found = 1; break; /* Don't have to check any more */ } } if (acceptable_found) lcd_printxy(1, 1, "Yes"); else lcd_printxy(1, 1, "No"); return 0; }
how about this code? please tell me if there is any mistake
I thought you said you were going to take some time to do some study?
I think that would be a far better way to spend your time rather than randomly throwing code around...
Be sure to look-up the use of the volatile qualifier...
There are several errors. But don't you find them when you test your code? You are realizing the existence of a debugger?
1) Your ISR don't do anything in case the input buffer already is filled. 2) You let the ISR pick up 12 characters. Are you sure the 12th character of input[] would match the 12th character of your reference keys? 3) How do you get your ISR to synchronize the input, in case you miss one character or there is one character too much? Consider what happens if you disconnect/reconnect the serial cable while data is transmitting? Wouldn't it be good to consider '$' or '\r' or '\n' as synchronization characters? 4) Why do you send back null characters?
SBUF=0;
Or do you happen to believe that writing 0 to SBUF is clearing the just received character? 5) Do you really think it's safe to ignore the input_done check in main()? How fast can the ISR find 12 characters? How fast can main() start calling memcmp()? 6) Haven't we already discussed the bad idea of having the program run out of main()? 7) Do you happen to think that the 8051 processor works best when it has 16-bit integers to operate on - or you think it needs the "int" data type to fit the values 0 and 1 (or the input position)?
1) Your ISR don't do anything in case the input buffer already is filled. 2) You let the ISR pick up 12 characters. Are you sure the 12th character of input[] would match the 12th character of your reference keys? 3) How do you get your ISR to synchronize the input, in case you miss one character or there is one character too much? Consider what happens if you disconnect/reconnect the serial cable while data is transmitting? Wouldn't it be good to consider the dollar or '\r' or '\n' as synchronization characters? 4) Why do you send back null characters?
#include<reg51.h> #include "_LCD_R8C.c" #define INPUT_LENGTH 11 char input[INPUT_LENGTH]; /* The input from the serial port */ int input_pos = 0; /* Current position to write in the input buffer */ char getCharacter (void); /* read a character from the serial port */ int main() { int i; lcd_init(); lcd_clear(); SCON = 0x50; TMOD = 0x20; TH1 = 0xFD; TR1 = 1; TI = 1; RI = 1; while(1==1) { /* read the next character from the serial port */ input[input_pos++] = getCharacter (); for(i=0;i<=input_pos;i++) { lcd_print_b(input[i]); } } } char getCharacter (void) { char chr[INPUT_LENGTH]; /* variable to hold the new character */ while (RI != 1) {;} chr[input_pos++] = SBUF; RI = 0; return(chr); }
first I tried displaying on the hyper terminal. I am getting correct value on the hyper terminal then I tried displaying the received number on the display, but I am getting the wrong value 002100 instead of $0016221826..
The trial-and-error continues.
Why have a getCharacter() function that has a local array chr[INPUT_LENGTH]? What do you think this one is used for? You receive one (1) character. You place it at a specific index in chr[].
Then you do something very interesting. You take the address of the array chr[] (yes, the name of an array represents a pointer to the first element in the array) and decides to convert this address into a character to be returned.
Haven't you got that C programming book yet? It would have told you a lot about how to use arrays. It would even have told you that the getCharacter() function have zero reason to contain an array since it is only intended to pick up one (1) character from the serial port and then return that single character.
Another thing - I have multiple times asked: Why do you print multiple characters to the LCD whenever you receive one more character? Don't you find it confusing to try to understand the printout on the LCD? Because I see no code that clears the LCD and start each loop by printing from the start of the line.
So if you receive the caracters 12345 on the serial port, your code would like to print 112123123412345 on the LCD - how helpful is that?
Or in reality - your LCD prints doesn't even print that. Because you print 2 characters when you have received 1. You print 3 characters when you have received 2. So the last character printed is always some data remaining since the previous iteration of your loop.
Yet another thing - you have an array with room for 11 characters. And an infinite loop repeating getCharacter() and then printing. What happens when you receive the 12th, 13th or 100th character? Where does it get saved?
Don't you think that a C text book and some quality time with a debugger would give better progress? Thowing LEGO pieces up in the air and check where they randomly land isn't likely to produce a nice castle or space ship. Right now, you are cutting/pasting/moving around source code without actually trying to understand what is actually happening. You can continue for 10 years without getting a working program, because it really is quite hard to throw 50 dices and get all 50 to show the value "6" at the same time. With better methodology, you could throw the first dice until it shows a "6". Then take the second dice and throw until you get a "6". Then the third. Then the fourth. That would give progress. The information from a C text book could give progress. The use of a debugger could give progress. Random code changes are likely to break as much as improving. So the probability of progress is very low. That is the reason why the days are ticking, while your school buddies have probably already managed to get their implementations to work by now.
Shortcuts can be very good when you know where they lead. Random shortcuts are known to lose time or get people completely lost.
ya your right, but what to do, I need to submit this program as fast as possible. . only 2 days remaining. I have studied the comparing of arrays and that part is completed. The only problem is in receiving char using interrupt and displaying it.
Now I have corrected all the mistakes still it is displaying 255 on the display.
once i am able to receive the char then I will finish off this program and take a break to study.
even I am feeling very bad.
Now I have corrected all the mistakes still it is displaying 255 on the display. HUH? if it is "displaying 255 on the display" it is not possible that you have "corrected all the mistakes"
once i am able to receive the char then I will finish off this program and take a break to study AKA sequencing error
since the above read and display characters one by one why are you using arrays? what happens if you do this
lcd_print_b ('U');
you are making the mistake of writing code instead of growing code. get one thing to work at a time.
ya i am getting the same display like 112122123. . please help me to complete the program
lcd_print_b ('U');.. I am not getting.. please explain in detail.
#include <reg51.h> #include "_LCD_R8C.c" #define INPUT_LENGTH 11 int main() { char input[INPUT_LENGTH]; /* The input from the serial port */ int input_pos = 0; /* Current position to write in the input buffer */ lcd_init(); lcd_clear(); SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; RI = 1; while(1) { /* read the next character from the serial port */ if(input_pos < INPUT_LENGTH) /* check for buffer overflow */ { input[input_pos] = getCharacter(); lcd_print_b(input[input_post]); /* only makes sense to print each character once */ input_pos++; } } char getCharacter (void) { char chr /* variable to hold the new character */ while (RI != 1) ; chr = SBUF; RI = 0; return(chr); }
i am getting display as 255... help me out...
