Pointer/Function help
So, I am trying to put together two (rather involved) functions that calculate the DAC. My processing routine for CalcDAC1 and CalcDAC2 are more or less the same, but with different variables. Currently, I'm using global variables that are directly called from the routine. I would like to use the same functionality but send it the variables I want the program to use to process so instead of:
global variables:
unsigned int var1a;
unsigned int var2a;
unsigned int var3a;
unsigned int var1b;
unsigned int var2b;
unsigned int var3b;
void main(void)
     while(1)
          CalcDAC1();
          CalcDAC2();
void CalcDAC1(void)
//Do stuff with var1a
//Do stuff with var2a
//Do stuff with var3a
Void CalcDAC2(void)
//Do stuff with var1b
//Do stuff with var2b
//Do stuff with var3b
I instead would like to do
void main(void)
     while(1)
          CalcDAC(var1a, var2a, var3a);
          CalcDAC(var1b, var2b, var3b);
void CalcDAC(unsigned char var1, unsigned char var2, unsigned char var3)
Unfortunately, my particular function has about 7-10 variables (complicated equation with lots of variables) so it requires me to create a LOT of local variables for each iteration, which I don't have the local space for (if that's the right term). Instead, I would like to send it pointers to local variables (if possible).
I ASSUME it would look something like this:
void main(void)
     while(1)
          CalcDAC(*var1a, *var2a, *var3a);
          CalcDAC(*var1b, *var2b, *var3b);
void CalcDAC(unsigned char *var1, unsigned char *var2, unsigned char *var3)
Is this correct or is this even possible in C? Is this something you can only do in C++? Any help with implementation you can give me would be greatly appreciated. Thanks!
  • Heh, thanks for the reply. I wasn't sure of the word I needed (as stated in previous posts) but I had a feeling "register" was the incorrect word.
    Regarding the chip/code I'm using, just to specify based on what you share, I am using a M8051W chip, which has 256 bytes of on chip RAM so I have:
    8K code space (I am currently utilizing just under 7K of it)
    128 bytes of Data space (which is all used up)
    128 bytes of Idata space (of which I'm using approximately 62 bytes of it)
    No Xdata on my chip
    The ESFR and SFR registers are all assigned to various functions of the chip
    Right now, I seem to be juggling between data/idata space and code space so I'm trying to find the most efficient ways of doing so, hence why I come to this forum. I can mickey mouse my code and MAKE it work but I'd rather learn how to do things correctly from people who have coding experience, hence why I came here.
    Thanks for the links you gave me. I will check them out. Thanks for the help!
  • On a sidenote, is there any reason everything designed by Keil or anything related to the 8051 looks like it was designed in the 90's? Every tool or forum looks extremely dated. Is that because long time programmers don't like changes or are the developers unable/unwilling to update the look/feel of the program? For a $2k-3k piece of software, you'd think they'd want to make it look a bit more up to date.
  • Right now, I seem to be juggling between data/idata space and code space so I'm trying to find the most efficient ways of doing so, hence why I come to this forum. I can mickey mouse my code and MAKE it work but I'd rather learn how to do things correctly from people who have coding experience, hence why I came here.
    basically the right way is to base it on "access frequency" and size.
    the stack (which is indirectly addressed anyhow is automatically placed at the top of (I)DATA which is where it belongs
    frequently accessed "directly addressed" variables should be in DATA
    frequently accessed "indirectly addressed" variables (straucts, arrays) should be in DATA
    large stuff should be in XDATA
    take a peak on the generated assembler for this
    char xdata x;
    char idata i;
    char data  d;
    bit  bdata b;
    char justFun j;
    j = x;
    j = i;
    j = d;
    j = P0;
  • Sorry, I completely forgot to get back to this. I got everything working. Thanks a lot for the explanations!
  • i have the same problem exact. what you did do to fix it?
    waiting for honest reply.
  • Exactly what specific problem.
    And exactly what do you find haven't already been answered in this thread?
  • hi. i dont understand the bdata and xdata and idata and code and bit. what is it doing?
  • Then you do not have exactly the same problem and this thread isn't for you.
    Start my reading some documentation about the 8051 architecture, and the different memory address spaces it has, and the corresponding processor instructions for addressing data in the different memory address spaces.
    You may also take a quick look on Wikipedia about Harvard and Von Neumann architectures.
    It's hard to look into the finer points of architecture-specific keywords for the C compiler, if you don't understand the architecture that the compiler have to map the generated code to.
  • i dont understand the bdata and xdata and idata and code and bit. what is it doing
    you need to familiarize yourself with the processor, and the best place is "the bible" chapters 1, 2 and 3, you can find a link here www.8052.com/.../120112
  • my book doesnt have them in the index. why dont you tell me what they are for?
    it it is not a '51 book it will not. if it is a '51 book, look for "memory areas"
    sure, but there is not room to write 25000 words in a post. READ "THE BIBLE" (link in above post)
    if you are one of those i eh people that believe "C is C" then drop all intents of working with micros.
  • what do you mean. i am using keil c. it understand normal c programs?
  • If the Keil C compiler have extra keywords - added specifically because the 8051 processor is a bit different from normal processors - that relates specifically to the 8051 processor, then you might be able to realize the need to figure out exactly what is different with the 8051.
    A normal processor can't address individual bits. So the C language don't have "bit" as a data type. So what happens if a user wants their C program to take advantage of the specific bit commands in the 8051 processor?
    A "normal" processor don't have multiple memory regions that all can have address 0 (zero) but that represents totally different data. So a "normal" C compiler don't need ways for the programmer to specify which memory region that should be accessed.
    So - have you read up on the 8051 architecture yet? Because you will not be able to understand the extra 8051 keywords before you have understood the specials with the 8051 architecture.
    And by the way - why are you still asking questions in this thread? This thread was about when to use the different regions. Your problem is to even understand that they exist. Why they exist. And why you need to know that they exist. First them, will it be possible to debate the advantages of making use of them in different ways - which this thread was about.
  • if you are one of those i eh people that believe "C is C" then drop all intents of working with micros.
    evidently you are.
  • The most amazing part is that, who should "drop all intents of working with micros", are good experienced developers of micros, here in my current company.
    I had tried so many times, but had failed again and again, just to convince them that, different processors have different architectures. And of course, they believe there is only one assembly language on earth, which is the traditional PIC assembly.
