Hi. What is/are the difference(s) between the following:
PxMDIN = 0xFF; // all pins on port1 are digital input with optional weak pullup. PxMDOUT = 0; // all pins on port1 are digital input as open-drain (no pullup).
Thank you.
But if you didn't mean the fc available in a common version of Windows like Win 7, that just means that you did an even bigger error to just write "fc" - especially since it is you specifically that claims that used program is important (and diff just for poodles).
Why not continue to post statements that backs my claim that you gave too little info in that post :D
Probably not a genuine tool.
Re:
[--discard-bullshit=level]
Automatically filters out???
[--turbo-boost=pump]
Makes the PC run faster than???
[--mysterious] [-N leaves] [-J panic] [-Hauqtcipo]
Well, I just assumed all better file compare tools (not intended for poodles) needed such arguments. Should keep the user occupied for a while, trying them out.
whos da poodle? ahh. yous da poodle.
Whatever.
