i am working on following project. & its showing me some errors... & i am unable to remove them... please help me out...
program:-
/*HEADER FILES*/ #include<reg51.h> #include<string.h>
/*LCD PIN CONNECTIONS*/ #define lcd P0 sbit rs=P0^1; sbit en=P0^3;
/*LCD FUNCTIONS DECLARATIONS*/ void init_lcd(void); void cmd_lcd(unsigned char); void data_lcd(unsigned char); void str_lcd(unsigned char *); void Delay_ms(unsigned int);
/*KEYPAD PIN CONNECTIONS*/ sbit row0=P2^3; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^0; sbit col0=P2^4; sbit col1=P2^2; sbit col2=P2^1;
/*MOTOR PIN CONNECTIONS*/ sbit M1=P1^0; sbit M2=P1^5;
/*BUZZER PIN CONNECTION*/ sbit BUZZER=P1^2;
/*VARIABLES DECLARATION*/ unsigned char i,j; unsigned char colval,rowval,pwdchange;
unsigned char pwd[15],temp[],str1[]="12345";
unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',}; /*PASSWORD FUNCTION DECLARATION*/ void password(void);
/*KEYPAD FUNCTION DECLARATION*/ unsigned char key(void);
/*MAIN FUNCTION*/ main() { unsigned char k=0; BUZZER=0; //BUZZER OFF M1=M2=0; //MOTOR OFF
init_lcd(); //LCD INITIALIZATION FUNCTION CALLING str_lcd("ENTER PASSWORD:"); //DISPLAY STRING ON LCD while(1) { cmd_lcd(0xc0); //2ND LINE DISPLAY password(); //PASSWORD FUNCTION CALLING if(pwdchange) { pwdchange=0; continue; } if(!strcmp(str1,pwd)) //COMPARING WITH 1ST PASSWORD { BUZZER=0; //BUZZER OFF cmd_lcd(0xc0); str_lcd("DOOR OPEN");
M1=0; //MOTOR RUNS IN FORWARD DIRECTION M2=1; Delay_ms(30); //30 MILLISECONDS DELAY cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; Delay_ms(1500);
cmd_lcd(0xc0); str_lcd("DOOR CLOSE");
M1=1; M2=0; Delay_ms(30); cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; k=0;
} else {
strcpy(temp,pwd); cmd_lcd(0x01); str_lcd("Confirm Password"); cmd_lcd(0xc0); password(); if(!strcmp(temp,pwd)) { strcpy(str1,temp); cmd_lcd(0x01); str_lcd("Password'Changed"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else {goto label;
} else { goto label; }
else { label:pwd[i++]=j; data_lcd('*'); }
pwd[i]='\0'; }
//its showing 4 syntax error near else...
Then you need to speak to your teacher, and request extra time! He/she will, of course, expect you to give a very good reason for the extension...
"i tried a lot but then also i was uable to remove those errors"
Then, again, you need to speak to your teacher - that's the correct place to go when you're stuck with your homework!
Per Westermark
i agree!! i"ll try again...........:)
hi!! tell me exact syntax for if with multiple else.. with using goto... as u said i changed some sentences... but its giving me same errors...:((
please explain me with some example... you are my teacher now!!
I'd like to see how you do that too ;)
There are no syntax for if with multiple else. There can only be zero or one else statement for every if statement. As I already mentioned, it is a logical impossibility to know which of multiple else to use if there isn't an "if" statement with a logical expression that performs the select of which of the two alternatives to use.
In some situations, it is possible to use a "computed goto".
One implementation of that is the switch statement in C.
Another implementation (better suited for processor architectures that doesn't suffer huge costs from indirect memory accesses) is tables with function pointers.
But your code is not a situation for any computed goto. You do not have a "one-out-of-ten" problem. You have a sequential problem. Each action can potentially trig a following action.
If A fails, we are done. Else we do B. If B fails we are done, else we do C.
This is a trivial problem that can be seen as having a number of postit notes and move around them until you get the most "beautiful" structure.
Note that the outcome of nested if/else can change drastically depending on if you favour the "if" part or the "else" part. Is it the "if" part that represents a failure? Or the "else" part?
A slightly naughty method for multiple error exits is the abuse of a loop:
do { if (!do_a()) break; if (!do_b()) break; ... if (!do_z()) break; // wow - we managed everything. return good_result; } while (0); // ouch - something went bad do_error_recovery(); return bad_result;
But no - your problem is not a problem that should make use of the above code. Your teacher would probably give you a long speech if you try that route.
So why not just consider the following?
if (xx) { do_a(); } else if (yy) { do_b(); } else if (zz) { do_c(); }
By the way - several days later. Aren't your deadline up yet? This is not a tough problem. It's rather easy. And there are a number of acceptable solutions. But "break" and "goto" should not be needed or used for this problem.
now its showing me 5 errors... '(' expected instead '{' near 1st else if statement.. and remaining syntax errors are as it is... :( :( (
/*HEADER FILES*/ #include<reg51.h> #include<string.h> /*LCD PIN CONNECTIONS*/ #define lcd P0 sbit rs=P0^1; sbit en=P0^3; /*LCD FUNCTIONS DECLARATIONS*/ void init_lcd(void); void cmd_lcd(unsigned char); void data_lcd(unsigned char); void str_lcd(unsigned char *); void Delay_ms(unsigned int); /*KEYPAD PIN CONNECTIONS*/ sbit row0=P2^3; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^0; sbit col0=P2^4; sbit col1=P2^2; sbit col2=P2^1; /*MOTOR PIN CONNECTIONS*/ sbit M1=P1^0; sbit M2=P1^5; /*BUZZER PIN CONNECTION*/ sbit BUZZER=P1^2; /*VARIABLES DECLARATION*/ unsigned char i,j; unsigned char colval,rowval,pwdchange; unsigned char pwd[15],temp[],str1[]="12345"; unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',}; /*PASSWORD FUNCTION DECLARATION*/ void password(void); /*KEYPAD FUNCTION DECLARATION*/ unsigned char key(void); /*MAIN FUNCTION*/ main() { unsigned char k=0; BUZZER=0; //BUZZER OFF M1=M2=0; //MOTOR OFF init_lcd(); //LCD INITIALIZATION FUNCTION CALLING str_lcd("ENTER PASSWORD:"); //DISPLAY STRING ON LCD while(1) { cmd_lcd(0xc0); //2ND LINE DISPLAY password(); //PASSWORD FUNCTION CALLING if(pwdchange) { pwdchange=0; continue; } if(!strcmp(str1,pwd)) //COMPARING WITH 1ST PASSWORD { BUZZER=0; //BUZZER OFF cmd_lcd(0xc0); str_lcd("DOOR OPEN"); M1=0; //MOTOR RUNS IN FORWARD DIRECTION M2=1; Delay_ms(30); //30 MILLISECONDS DELAY cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; Delay_ms(1500); cmd_lcd(0xc0); str_lcd("DOOR CLOSE"); M1=1; M2=0; Delay_ms(30); cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; k=0; } else { strcpy(temp,pwd); cmd_lcd(0x01); str_lcd("Confirm Password"); cmd_lcd(0xc0); password(); if(!strcmp(temp,pwd)) { strcpy(str1,temp); cmd_lcd(0x01); str_lcd("Password'Changed"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } else if { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } } else if { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } } else if {goto label; } else if { goto label; } else { label:pwd[i++]=j; data_lcd('*'); } pwd[i]='\0'; }
You are having a laugh, aren't you?
You need to go back to absolute basics!
www.loirak.com/.../ctutor.php
Look at
3. Loops and Conditions
even better, get a C book e.g. Kochan "programming in ANSI C" and learn C on the PC. C51 is not a good learning platform.
The goto statements are still there.
But now you have "introduced" a new version of C syntax:
... } else if <= if what? { cmd_lcd(0x01); ... }
Have you ever seen any text book describing any if statement that doesn't have a conditional expression? Exactly what would an "if" statement do, if you don't give it a condition?
Absolutely!
You have basic 'C' syntax errors - you need to go back to your 'C' textbook, and your 'C' class notes, and study them carefully!!
More basic 'C' learning links here: blog.antronics.co.uk/.../
I would argue that knowing C syntax isn't the biggest issue here.
For someone wanting to figure out a way to utilize multiple "else"s following one "if", growing a functional brain is probably far more urgent.
oh yeah!! now i got this... there should be some condition... in this syntax...
tell me the procedure to remove this errors from begining.. it will help me to understand the things.. because if i do that on myself , errors are increasing...:((( can i get your e-mail id??
Please start reading this thread from the top. Stop after each entry and _think_ about what you read and what it says (about your abilities, not the posters!).
Already covered in one of the first posts of this thread.
