Dear all,
I have this ultra simple strcture
typedef struct { uint8_t Hora; uint16_t Data1; } EEpromPaqueteDatosS;
When I do sizeof(EEpromPaqueteDatosS) it returns 4!!! But if I do the sizeof of the same structure with only one variable, in other words, with uint8_t variable it returns 1 and with uint16_t it returns 2.. but if the structure have the two variables it returns 4!!
Also if I copy the structure to a uint8_t vector I can found a strange byte in the middle.. like this:
EEpromPaqueteDatosS EEpromPaqueteDatos; uint8 data[4];
EEpromPaqueteDatos.Hora = 0x10; EEpromPaqueteDatos.Data1= 0x1020;
When I copy the structure to data, data is like 0x10, 0x??, 0x20, 0x10.. why this extra byte!!!!
Can anybody help me with this???
if so Keil (recent version) breaks the "language definition"
I'm with Per on that one: it'll take actual evidence to convince me of that. In a new thread, preferrably.
I do not know the "language definition"
And you say that (here and elsewhere) as if you're proud of it. I think you rather should be ashamed of it.
The problem is solved
No, it's not. You only believe it is, solely based on picking exactly the wrong pieces of information out of the wealth you've been given.
and this discusion have no sense now,
You're wrong about that. Just because you refuse to learn something doesn't mean others can't.
