hi i am final year student of electrical engineering and doing a project on 8051 microcontroller. in this project,i have to interface the 8051 to maltab for real world data.i successfully complete the interfacing and communicate serially on proteus.data which is transfer from 8051 to matlab is not accurate when i send more than one character.in single character, matlab does not show any data.plz help me,how to solve that problem as i am using 8051 first time.
will get back to you as soon as i get to try this out.
Aniket
Didn't get a chance to reprogram my chip with the scoping code yet, but I tried out the same thing with my present code and got unexpected results- 50kHz square wave..can't understand what the problem could be.
tell nothing
tried the scoping code today...got the same result..square wave with 50kHz frequency.
I can't see a reason for 50kHz, but easily see 50Hz.
is it really kilo Hz?
yes it was definitely 50kHz.
Verified again today; actually it wasn't a complete square wave, just 230mV dropping down from 5V with a frequency of 50kHz to 52kHz. Could something be wrong with the port?
if you are not working with a PCB state so if you are: do you have a ceramic cpacitor from Vdd to gnd with less than 1cm traces to the chip are the traces to the xtal and burden caps less than 1cm
One of the pins of the xtal along with a burden cap pin, which are connected to pin 18 of 8051 have a physical distance of exactly 1cm from pin 18 - hence the length of the PCB track joining them must be very slightly greater than 1cm. The other pin going to pin 19 has a distance of almost 1.5cm. Apart from the burden caps there's only one other ceramic cap (rest all being electrolytic) present in the power supply unit, one end connected to gnd and the other to pin 40 for Vdd, dist between that pin and pin 40 is almost 1.5cm.
one other ceramic cap (rest all being electrolytic) present in the power supply unit, one end connected to gnd and the other to pin 40 for Vdd, dist between that pin and pin 40 is almost 1.5cm "a wire/trace is not a wire"
PLEASE do not use pin numbers, I GUESS "pin 40" is Vdd. (I have not used DIL for ages) how long is the trace from the other end of the cap to the gnd pin "gnd is not gnd"
rest all being electrolytic does that mean aluminum or tantalum?
just to check, solder a ceramic 10-100nF directly to the gnd and Vcc pins on the uC
What does a scope set to AC 1V show on the Vdd AT THE uC?
you, probably, should post at 8052.com instead
I'm sorry I didn't understand the statements, "a wire/trace is not a wire" and "gnd is not gnd".
When all you have is DC, a trace on the PCB can be seen as a resistor with a very low resistance.
When your current consumption is pulsed, which it is in a clocked digital circuit, then the PCB wires are no longer just resistors. They behave as if they have capacitance and inductance. So you need to take care - for example reduce the current pulsing in the wires by having decoupling capacitors as close at is possible to VCC and GND of all your chips.
If you have digital inputs unconnected, the radio-frequency energy radiated from other signals can be enough to get an open digital input to jump randomly between zero and one.
