SD CARD FIFO
Im trying to implement a SD Card Interface.
I'm having a doubt..
I´m able to initialize and write and read data.
But it is so crazy the data I'm reading!!
I try to write 0,1,2,3.... And when I read I dont get this sequence.
I guess the problem is the way I'm writing in MCI_FIFO.
When I'm writing I set all necessary registers (lenght, timer..)
And then I initialize the transfer:
MCI_DATA_CTRL |= 0x91;
Then how should I write the code to put data in MCI_FIFO?
IF I do a for like this:
for(x=0; x<128;x++)
 MCI_FIFO = x;
but it makes no sense, what is the right way to do this?
Help me!
  • MCI_FIFO[1], MCI_FIFO[2]..
    That does not work...
    So you need to think about why that does not work!
    This is basic 'C' programming: what type(s) of items can be used with [] as an "offset" or "index" operator...?
  • Yes, my methods do work.
    It's just you who have decided that "my methods" means something else than they do.
    An integer is an integer. Just a number without any fractional parts.
    An integer variable has an address and can store an integer.
    An integer variable can not be used as a base for indexing. After all, it is not an array but an integer variable.
    The address of an integer variable is a pointer.
    A pointer can be used for indirection.
    A pointer to an integer variable can be used for indexing integer values.
    A pointer can also be used for memcpy().
    This is covered early on in books for learning C. Why start with a memory card program, until you have learned basic C data types, and how they relate to each other? As you have already noticed, you get really frustrated when you get stuck at every step. Not our fault, but caused by you trying to reverse the order of things. You try to write poetry before you have learned how to read and write. You try bike racing before you have learned how to keep the balance on a bicycle.
    Doing things in the correct order, means you can feel good when you have managed to master something new. Every step you manage is a level up. Doing it the reverse way is just leading to frustration. Fighting the end boss before you are geared up just results in wipes. You fail. You have to restart. You fail again. New restart. New fail. Repeat until you give up. Because that is the end result if skipping the basics. Instead of seeing LEGO pieces that can be combined, you see black voodoo magic.
    Any help we give you, will only get you one puny step forward, before you get stuck again. And again. And again. To get forward, you must learn what LEGO pieces you have available, and how they can be combined.
  • You're all so smart!!
    And neither you know how to solve the problem! kkk
    Congratulations!
  • You're all so smart!!<
    You have no idea.
    And you really believe you are in a position to be the judge of that?
    Congratulations!
    You can keep those to yourself, thank you very much. Nobody wants to be congratulated by you.
  • Do you actually want to learn how to do this stuff for yourself - or not?
    If you're not interested in doing this stuff, that's fair enough - it's not for everybody - but that's no reason to expect others to do it for you for free.
    I am not interested in doing accountancy, so I pay an acountant to do that stuff for me - but I don't expect him to do it for me for free!
  • I have done a "fill in lines between the numbered dots" for you.
    You can solve it directly from my text. If you do known the syntax for pointer indirection, address-of operator, indexing, ...
    If not, then it should be very easy to figure out what chapters to take a closer look at in a C self-study book.
    It's just that it isn't meaningful to tell you how to perform indexed writes to the FIFO as a magical line. If you do not spend the time to understand why and what, then you will just get stuck again 5 seconds later.
    Your question is a bit like "what is the product of 7 * 9?" A quite easy question. But if you don't understand multiplication, it will suddenly be a very hard question. And if someone do tell you the answer is 63, you would still be just as stuck, because you would still not understand how multiplication works.
    So the solution to your problem is to send a couple of hours reading up on pointers and arrays. It would be well invested time. And you would need this knowledge anyway, to get through any real application. One reason for that is that pointers are so integral to C code. C makes use of pointers in many situations where other languages have more specialized ways of writing code.
