We are evaluation Keil uVision V4.10 and ARMCC V4.1.0.481.
Our first test run didn't go so well.
With no optimisation, everything worked OK. Using optimisation 1 or above, the test failed.
For various reasons, I can not disclose the test source code. However, I will attempt to create a small self-contained example later on. The part of the test code that caused the problem is setting up an multi dimensional array, setting each element to '1' (ie. Array[x][y] = 1 with a for loop for both x and y).
In the meantime, I wonder if anyone has had a similar problem?
Using optimisation -O3, the assembler code in the debugger looks like this:
48: for ( y= 0 ; y < 8 ; y++ ) 0x80000AAC E5C02000 STRB R2,[R0] 0x80000AB0 E2822001 ADD R2,R2,#0x00000001 0x80000AB4 E3A0C001 MOV R12,#0x00000001 0x80000AB8 E20220FF AND R2,R2,#0x000000FF 0x80000ABC E7C3C001 STRB R12,[R3,R1] 0x80000AC0 E5C02001 STRB R2,[R0,#0x0001] 0x80000AC4 EAFFFFFC B 0x80000ABC -- Isn't this an infinite loop???
I second that.
A fantastic machine indeed!
I'm not saying this is wrong but ... I don't quite like the space between 'y' and '++'...
Is this common practice to write like this?
There is no way I would release any code with a space between increment/decrement operator and the variable. I'm too much of a style police - whenever I see any space at the "wrong" place, my eyes hurt. But I limit myself to perfecting "my" code.
