HOW TO GIVE INPUT VALUES TO DATAPOINTER USING MEMORY. MY PROGRAM IS NOT TAKING IN ANY VALUES GIVEN @DPTR.</b >
gud one i luv the blah..blah..blah.!!!!
Here's the deal, OP. There are quite a few people here who are willing to help others.
For anyone to help you, you must clearly state you problem, preferably with an actual code example. If you post code, make sure you follow the instructions on how to properly post code. It makes it much more readable for the rest of us.
You should clearly state what you expect the code to do and what the code is actually doing.
If you don't want to listen to the advice of the people who take their time to try to help you, please go away.
ND
I DONT WANT ANY REPLIES FROM U
Three replies to that:
1) Given that none of the people who participate here is called 'U', that's an empty statement.
2) You're progressing really fast to the point where nobody out here is going to ever want to offer anything to you, ever again. Not even something as cheap as a reply.
3) Oh yes, you most definitely do want replies from us. If you didn't, you wouldn't have asked a question.
ill try to change myself
That promise is quite obviously a lie. You haven't changed a bit. You're still bolding every single one of your replies. You still refuse to clarify your original question in any away.
, my answer pls ??
To what question? How do you suppose anybody would be able to understand that gibberish, ripped out of context as it is?
Mr OP,
Some of us here are willing to help you, but you need to help us by helping yourself.
Just post a question that explains the problem clearly and correctly. Don't shout and don't use bold - You might then find you get a response you like.
He doesn't want or need an answer. He is just trying to torment and he will continue until he is finally ignored.
Unfortunately, I think you're right.
Ain't human nature strange?
