Admin - Call for forum enhancement requests
All,
I have noticed a few posts that have made some suggestions about forum enhancements.
As we're migrating and enhancing the site, there may be an opportunity to enhance the forum, as well. Some of the suggestions I have seen are:
  • Report a post. (inappropriate or unrelated content, spam)
  • Edit posts. Keil administrators already have this capability, but as the forum isn't heavily moderated, it may be useful to give this capability to users for their own posts, and in the case of frequent/valued contributors, for other members' posts.
  • Logins. We haven't required logins or account verification in the past 15 years because it has never seemed to be necessary. However, editing posts will require some sort of authentication to keep trolls from editing at random.
  • Move from discussion thread to question/answer format. Some sites (such as stackoverflow.com) use this quite successfully. It encourages on-topic posts and I feel improves the value of the forum archive as a technical resource.
  • UI changes. Entering a message on a separate page from the thread in a 50 character wide text box is less than ideal.Real-time preview would also be nice.
  • If you have any opinions on these or other enhancements/modifications, please post here or email me directly at david.lively@arm.com.
  • "automatic code snippet detection" has already been mentioned but, at the very least, the forum should be able to detect the presence of TAB characters and, thence, warn the poster specifically...
  • The display code could at least try to default to 4 or 8 character expansion of tab characters. Might be ugly but not as ugly as having all indent disappear.
  • Shall we take that as a vote for, "Report a post. (inappropriate or unrelated content, spam)", then?!
  • On the forum thread list:
    http://www.keil.com/forum/threads.asp
    Is it or would it be possible to ad some category filtering?
    Like: just ARM, just ARM7, just 8051, whatever...
    If there are any other categories/properties stored for the posts, would be nice to be selectable too.
  • -Will you allow:
    -Voting up and down the usefulness of an answer?
    -Click on a user name to see all his activity?
    -Badges for good answers / good questions?
    -Patchwork quilt avatars?
    -Mark a question as answered or unanswered?
    Also a mobile-friendly view for the forum would be nice
  • "Also a mobile-friendly view for the forum would be nice"
    The current forum isn't even PC-friendly in case someone posts "code" with a 500-character line.
    There should be a hard maximum width to code blocks with a scrollbar in case someone do post long source lines. Never, ever, should the "normal" text comments be stretched in width.
    If making the above change, it wouldn't hurt with a "copy" or "save" button beside the code segment. But that is a minor feature request. Not letting long source code lines break the formatting is a major feature request.
  • -Voting up and down the usefulness of an answer?
    tried in other fora and turned into a 'pissing contest'
    good idea
    what is that?
    I do not see how
    Why on earth, do we not have enough posts 'written' in Stupid Monkey Shit already?
    Yes, YES, yes
  • Good "karma" or whatever it is called often work out well.
    It's the negative votes that tends to result in big fights. Especially since it quickly becomes obvious that some people use them in a fight, i.e. A and B have an argument, and B uses negative votes on A:s comments. Only A and B online at the time with rights to vote, so very transparent.
    In a forum where everyone may give any number of + votes (but of course only one + vote/post) you get a situation where most posts gets one or more +. So the difference between a good and a bad answer is zero or one votes contra 10 or 40 votes. But you don't get any "revenge" involved in the voting - best revenge anyone can do is to avoid to vote. But their missing vote will not make much of a difference.
    The thing with votes is that they should help a reader without creating badwill from intentional punishments. http://www.8052.com sometimes (has been some time since last I saw it now) suffers from voting as personal agendas. But it has happened that posts have received "Answer is wrong" just because someone don't like a perfectly correct answer. But problems with negative votes are common everywhere.
  • >>Why on earth, do we not have enough posts 'written' in Stupid Monkey *** already?
    Maybe we could add an auto translate Stupid Monkey *** Translator.
    Instead of detecting tabs, or C code, it would convert
    "HI AFAIK I tryed testing my bored 4ever, it broke. Wut now? l8r"
    to:
    "Hello I type very poorly like I got hit on the head with a heavy object. I am having issues with an evaluation board. Any suggestions?"
    Do take David's suggestion and go to stackoverflow.com, get a feel of how it works. Click on the advertisements there.
  • Maybe we could add an auto translate Stupid Monkey *** Translator.
    you do that
    asking for a lot (not just the above) in a forum that is provided for free is not reasonable.
    The forum as it is works. Yes, it could use some improvements, but keep the fact that you do not pay for it in sight. I do not know what is involved with the various suggestions above, but what i suggest to David is that he does the following: FIRST require registration, then SECOND set up a voting (3 votes per registered user) on the list of suggested improvements that are within an acceptable effort to implement.
    finally one suggestion:
    A few strangely named creatures hide behind their monniker and spew bile on a regular basis. require registration and the real name used.
  • Joel Spolsky and Jeff Atwood wrote
    -Will you allow:
    Very good suggestions, most of these features are present on TI's discussion forum. I'm not sure that Keil monitors the forum enough to implement the answered/unanswered feature though.
    -Walt
  • Isn't it normally the OP who flags a thread as "Answered"?
  • I'm not sure how it is normally done but on the TI site, I believe that a TI employee has to verify that a question has been answered (I could be wrong). If the OP is a newie, how can he say for certain that he is being given good or bad advise.
