main_tcpnet() processing time
Hi every body,
I am in a bit trouble of finding out the processing time taken by main_tcpnet() function. As it is written in documents that this function must be called periodically but does not specify at how much rate i.e milliseconds. Secondaly since i have other work to do also during interrupt (timer) i wonder how to fix main_tcpnet() function in the same interrupt as doing this causes my hardware to reset.
Plz help me
Thanx in advance
  • Dear friends,
    Yesterday i have cracked the working of all the TCP stuff i.e main_tcpnet() and timer_tick() on LPC2300 using a logic analyzer. Here is the story:
    1) Timertick merely provides the time to TCP stack for its time calculations as configured in net_config.c. This is also written above by other members. Nevertheless it does't affect TCP performance as far as i have seen as i am calling timer_tick() aperiodically.
    2)Now the whole and sole of TCP is the main_tcpnet() function. As soon as you connect ethernet cable to board it make your code to run in ethrnet interrupt isr depending only upon the traffic and filter configuration.
    3)When main_tcpnet() is called it checks for any TCP data arrived (obviously for this to happen ethernet interrupt will ocuur first). If this is the case code will first exit from ethernet interrupt isr and after some microseconds it enters into callback() interrupt in the application code. In callback() isr routine we chk the arrived data and reply acordingly. After completion of this whole process we exit main_tcpnet().
    4)Thus the conclusion is main_tcpnet() processing time depends upon ethernet interrupt isr and callback() isr.
    And callback() interrupt or reply to ping will only occur if we call main_tcpnet() periodically.
    Please add you experince to this also
  • Hello friends,
    Long time no see, Ok i am in the way of completing my project as i called main_tcpnet() from the while(1) loop. Now in my way i am suffering from hurdles as i asked earlier. My latest hurdle is as follows:
    1) I have made 200 servers on LPC2300. A client (can be more then 1) will ask for running data from these servers.
    2) I have allocated different IP address to each (Please suggest me a way to dynamically allocate these addresses)
    3) Main hurdle is to allocate MAC addresses to each servers, Since the adresses are allocated by IEEE then what should i do to allocate it.
  • What i have understood from surfing is as follows:
    1) Hitex has purchased OUI (organization unique identifier) which is of three Most significant bytes which is 00-30-6C
    2) Rest of the three bytes are empty
    3) We have to apply for extension identifier that is assigned by the IEEE Registration Authority and then reserving an additional 12 bits for use by the assignee. The resulting 48-bit identifier uniquely identifies the assignee of the IAB and provides 4096 unique EUI-48 numbers for use by the organization that purchased the IAB.
    Example of EUI-48 created within an IAB:
    An EUI-48 identifier is formed by combining the 36-bit IEEE assigned IAB base value with a 12-bit extension identifier assigned by the organization â€" e.g., if the IEEE assigned IAB base value is FF-FF-FF-FF-F0-00 and the 12-bit extension identifier is hhh16, then the EUI-48 value generated by combining these two numbers is FF-FF-FF-FF-Fh-hh
