Hi all,
I'm using 89C52 controller in my application. I'm using a 90 byte buffer to store received message from UART. Based on this received message I'm controlling I/O ports. The same buffer I'm using for transmitting the application dependent internal status message.
To identify the message I'm using absolute address position for example, if(arr[59] == '*'){do something;}
every first message after reset this is working fine. After that the control hangs somewhere thus its giving undetermined behavior.
I set the memory model as Large: all variables in XDATA.
I hope some address overflow is happening here.
Can anyone help me to resolve this issue.
Thanks in Advance.
Regards, Ramesh
unsigned char message[35]; unsigned char Request[35]; for(i=0;i<=35;i++) { //Rx buffer for first 35 char's // controll waits here for incoming char message[i]=RX_CHAR(); process=1; } for(j=0;j<=35;j++) { Request[j]= 'A'; }
YOU ARE FILLIN G A 35 CHARACTER ARRAY WIT H36 CHARACTERS!
THAT IS OVERFLOW!
narak, don't you think it is only appropriate to also SCREAM in the code that you post?!
<QUOTE>don't you think it is only appropriate to also SCREAM in the code that you post?!</QUOTE>
HE DOES NOT WANT TO LISTEN TO MY ANSWER WHO I THINK IS CORRE CT!
IS HE DEF?
the OP probably already implemented your careful advise. there is no need to use UPPERCASE. that won't make his listen - just annoy everyone else.
Hi Narak,
I had already modified the code as below. But still its not working.
for(i=0;i<=34;i++) { message[i]=RX_CHAR();
I'm using Uvision3 IDE version 3.30a. I have not tried out with older version of IDE. Will it cause any problem??
