hello everyone, i am writing a program for c8051f020,in which i have 4 ".c" files: main c file,keyroutine file, general routines files,confguration file
i separated bit addressable, data addressable, functions, #defines in separate header files
i included these header files in respective ".c" file
but i am getting following error in linking
1. public refers to ignored segment 2.address space overflow both for data as well as bit memory 3.multiple public definitions
i have put all ".c" files for build shall i continue or main c file should be put for building
if i do so then for debugging i will not be able to put breakpoint in other c files
can you tell me how to include c file in another c file
for further details pls let me know
thank you all take care
Thanks Dan, I didn't know this about "_[A-Z_]..." identifiers.
Or from the "Embedded Muse 169" (www.ganssle.com/tem-back.htm):
Steve Strobel wrote about header guards: I have adopted an unconventional include guard to detect and warn about such header include loops. It is even bigger and uglier than the standard include guard (which I think is ugly), but has saved me lots of frustration by letting me know when a cycle exists before I waste time trying to track down a bunch of related compiler errors. //------------------------------------------------------------ #ifdef main_h_include_finished #elif defined(main_h_include_started) #warning "HEADER FILE INCLUDE LOOP!!!" #else #define main_h_include_started //------------------------------------------------------------ // header file contents go here //------------------------------------------------------------ #define main_h_include_finished #endif //------------------------------------------------------------
Not sure though why he added "main_h_include_started", seems unnecessary, but adding a #warning is nice. As long as you don't have legacy spaghetti code that includes everything everywhere and a build system/compiler that stops on warnings :-)
Just a follow-up about guard code for defines and guard code around individual symbols.
Guard code around an individual symbol may seem good, but have a big implication:
lib_header_1.h
#if !defined(MY_CONSTANT) #define MY_CONSTANT 10 #endif
lib_header_2.h
#if !defined(MY_CONSTANT) #define MY_CONSTANT 20 #endif
source_file_alt1.c
#include "lib_header_1.h" #include "lib_header_2.h" int my_data[MY_CONSTANT];
source_file_alt2.c
#include "lib_header_2.h" #include "lib_header_1.h" int my_data[MY_CONSTANT];
The end result will be an application that behaves differently depending on the include order of the two header files, and the developer will have no good way of figuring out why.
It is better if a library function either has a really hard limit, or is written to take the limit at run time.
But for a nother case - guarding full header files.
comlib_type_defines.h
typedef unsigned char comlib_uchar;
comlib_protocol1.h
void library1_function(comlib_uchar a);
library_protocol2.h
void library2_function(comlib_uchar a);
Now it would be nice if an end user may use either library_protocol1, or library_protocol2 or both, without having to know that the two protocol libraries have a common part with a common header file, i.e. all four examples should be allowed:
example_only_1.c
#include "comlib_protocol1.h" ...
example_only_2.c
#include "comlib_protocol2.h" ...
exampley_both_a.c
#include "comlib_protocol1.h" #include "comlib_protocol2.h" ...
example_both_b.c
#include "comlib_protocol2.h" #include "comlib_protocol1.h" ...
But it is important to note that comlib_protocol1.h, comlib_protocol2.h and the common file comlib_type_defines.h may not play with conditionally defined symbols. As soon as the end user is allowed to replace the value of an individual symbol, the developer got a vey big loaded gun preaimed at his/her own foot.www
