Hello. I need some help. I'm trying to write, read and erase an external EEPROM (25AA040 MICROCHIP) via SPI from XC164CS board, for example, one byte at 0x00 adress of the eeprom, but i don't know how to do it. Into the datasheet, I can see some instructions but i don't know what to do with them: img28.imagevenue.com/img.php Could anyone help me? Thank you very much. :)
Then, shall I only have to adjust the EEPROM struct? I will try. By the way, we have already bought the Keil uLink2 JTAG Debugger for training my project and future developments :)
You would need to change the values in the enum EepromCommandType and also modify the start address of the variable eeprom.txptr in the function EepromStartTx.
1-. Aren't the values of EepromCommandType enum constants?
2-.
... eeprom.txptr = (S8 *)(&eeprom); /* reset pointer to first element */ ...
This type of instruction is new for me and I dont know it very well. I know that the pointer is reseted to fist element but could you explain me a bit? How to change the value of eeprom.txptr Thank you
John, First allow me to recommend that you refer to a C text book to extend your understanding of pointers. I don't know what kind of application your are writing, but do remember that making a mistake with pointers is likely to kill your controller, and could risk lives in the process! as to your question:
'eeprom' is a data structure that contains a member pointer to a 8 bit data type (that is 'txptr'. we can assume it is a unsigned char). that member is pointed to the beginning of 'eeprom'. that means that dereference of 'txptr' will be an unsigned char, or the first byte of the 'eeprom' structure, where I guess some text is stored (see the structure layout). note that incrementing the value of txptr by 1 will point it to the next unsigned char of the structure.
&eeprom
returns the address of 'eeprom', and that address is then casted to a unsigned char pointer so that the assignment will not cause the compiler to complain.
Ok Tamir, I understand your text. I have a new question. If I have to increase the pointer "x" times, is necessary to intriduce a new parameter in the function? For example:
_inline void EepromStartTx(U16 MY_ADRESS) { CS_EEPROM = low; eeprom.bytesTx = 1; /* decrement the transmit count by one */ eeprom.bytesRx = 0; eeprom.txptr = (S8 *)(&eeprom); /* reset pointer to first element */ eeprom.txptr = eeprom.txptr + MY_ADRESS; /* put the pointer in my first element */ SSC0_TB = *eeprom.txptr++; /* write the first byte to the SSC0 tx buffer */ }
can be compacted to
eeprom.txptr = (S8 *)(&eeprom) + MY_ADRESS ;
I would expect a function prototype like this:
void EepromStartTx(U16 MY_ADRESS, unsigned char *ap_buffer, unsigned int a_buffer_length)
note that I removed the inline directive as it might probably be required to insert a loop into your function.
Its imposible. If I modify anything in EepromStartTxthe EEPROM only returns zeros. Any suggestion?? I just need to know this :(
how then do you expect to solve your problem is you cannot change anything? there is a logical empirical explanation as to why it does not work anymore. why don't you post a revision that does not work.
The code is too long to post here. Take the proyect at this adress: rapidshare.com/.../eeprom.rar.html
I am not installing any of this rapidshare junk on my PC, and anyway I don't have time to review your code. The product hits the market by the end of this week! depart from a working revision, change your EEPROM write function, and post it here if it does not work.
I am not sure how you are going to maintain code that you didn't write or don't understand. The driver starts with the serial command and address then switches to the user address by a counter in the interrupt routine.
typedef enum { WRSR = 0x0100, /* Write Status Register */ WRITE = 0x0200, /* Write Data to Memory Array */ READ = 0x0300, /* Read Data from Memory Array */ WRDI = 0x0400, /* Reset Write Enable Latch */ RDSR = 0x0500, /* Read Status Register */ WREN = 0x0600, /* Set Write Enable Latch */ } EepromCommandType;
_inline void EepromStartTx(void) { CS_EEPROM = low; eeprom.bytesTx = 1; /* decrement the transmit count by one */ eeprom.bytesRx = 0; eeprom.txptr = (S8 *)(&eeprom)+1; /* reset pointer to first element */ SSC0_TB = *eeprom.txptr++; /* write the first byte to the SSC0 tx buffer */ }
#include <XC164.h> #include <intrins.h> #include "types.h" #include "utilities.h" #include "ssc0.h" #include "variables.h"
const S8 txBuf[] = "Welcome"; const U16 txSize = (sizeof(txBuf) - 1); S8 rxBuf[64];
/**/ void main (void) { U16 address = 0; /* EEPROM address */ U16 my_adress1 = 0; /* Write Adress */ U16 my_adress2 = 3; /* Read Adress */
SSC0_Init(); /* initialize the SSC peripheral */ ASC0_vInit(); /* initialize the ASC peripheral */ PSW_IEN = 1; /* globally enable interrupts */
DP9 = 0x0010; // load direction register
flag = 0;
/* write bytes to the EEPROM */ EepromWriteEnable(0); while(EepromBusy());
/* max page size if 64 bytes in a write */ EepromWrite(address, (S8 *) &txBuf[0], (U16) txSize,0); while(EepromBusy());
/* wait for WRITE command to complete */ while((EepromReadStatus(0) & RDY_) == true);
/* read back the bytes we wrote to the EEPROM */ EepromRead(address, &rxBuf[0], 6, 0); while(EepromBusy());
while(1) { _nop_(); /* loop forever */ } }
where is "EepromStartTx"?
What you have said, I understand it. What I don't know to do is how to modify the pointer to change the writing/reading start adress that I want.
_inline void EepromStartTx(U16 MY_ADRESS) { CS_EEPROM = low; eeprom.bytesTx = 1; /* decrement the transmit count by one */ eeprom.bytesRx = 0; eeprom.txptr = (S8 *)(&eeprom)+1; /* reset pointer to first element */ SSC0_TB = *eeprom.txptr++; /* write the first byte to the SSC0 tx buffer */ } /**/ void SSC0_viTx(void) interrupt SSC0TINT { if (eeprom.bytesTx < eeprom.txCnt) { eeprom.bytesTx++; if (TxMode == WRITE) /* write mode */ { if ((eeprom.cmd == WRITE) && (eeprom.bytesTx == START_TX_MSG)) { eeprom.txptr = eeprom.baseptr; /* switch pointer to data */ } SSC0_TB = *eeprom.txptr++; /* write user data */ } else { /* ok READ mode */ if ((eeprom.cmd == READ) && (eeprom.bytesTx >= START_TX_MSG)) { SSC0_TB = 0; /* when reading data just send zeros */ } else { SSC0_TB = *eeprom.txptr++; /* send command and address */ } } } } /**/ void SSC0_viRx(void) interrupt SSC0RINT { if (eeprom.bytesRx < eeprom.rxCnt) { eeprom.bytesRx++; if ((eeprom.cmd == READ) && (eeprom.bytesRx >= START_RX_MSG)) { ///////////////////////////////////////////////// mi_array[j] = SSC0_RB; j++; if (j == NUMERO) { flag = 1; ASC0_TBIC_IR = 1; } ///////////////////////////////////////////////// *eeprom.rxptr++ = (S8) (SSC0_RB); /* read user data */ } else { eeprom.data = (S8) (SSC0_RB); /* used for non-user data */ } if (eeprom.bytesRx >= eeprom.rxCnt) { eeprom.busy = false; /* indicate the resource is free */ CS_EEPROM = high; /* all data sent, release /CS */ } } }
