What is ?C_HCASTS
Hi.
I'm running Keil's C166/L166 compiling/linking software.
In the MAP file there is a PUBLIC SYMBOL ?C_HCASTS
with
REP LABEL
CLASS FCODE
SECTION ?C_LIB_CODE
I would appreciate it if anyone could tell me what ?C_HCASTS means. What it's for, what it does and everything else about it.
Neil
  • When generating code, the compiler automatically calls library routines for certain tasks, like copying structures, converting certain types, doing floating point arithmetics and so on. ?C_HCASTS sounds much like one of those routines. Why don't you load the program into the simulator, locate the code for ?C_HCASTS and see what it does?
    Regards,
    - mike
