Trouble with serial port work.
I was using Keil to program a Philips 89c51 chip last week to transmit data at 19200 bps. It was working perfectly, i got the data on the PC. I could also see the actual 0V - 5V waveforms on the TXD pin.
This week I switched the chip to an Atmel 89c51 33 MHz one..using the same program but can't see thevoltages on the TXD pin. Tried putting a load resistor to ground, then I can see the voltages but the chip is now not speaking to my PC. Do I need to be doing something different..?
thanks for all help..
  • 1. You must see if your AT89C51 can support 33MHz speed.
    2. If your Philips 89c51 and AT89c51 use different crystal, you must recalculate your register value of band rate.
  • This week I switched the chip to an Atmel 89c51 33 MHz one..using the same program but can't see thevoltages on the TXD pin.
    That's what you get for using Atmel :)
    Seriously: since you state "33 MHz one" did you change the crystal.
    another possibility, since you did not bother to state the whole derivative name (all Philips chips have a 'P') it could be that one was an x2 and the other not. or that one was programmed as an x2 and the other not because the (default and?) programming is different.
    a third possibility, since you did not bother to state the whole derivative name is that one chip has configurable pins .
    a fourth possibility, since you did not bother to state the whole derivative name is that the UART activation differ.
  • No...
    I didn't switch the crystal. Just mentioned that the new chip supports 33 MHz. I am still using a 11.059 Meg crystal.
    The point is, the program is executing fine and alongwith writing to serial port, i tried toggling port pins and the timing of that corresponds to approx 10 bits being put on the bus at 19200 bps. Except that I can't see the voltage on the TXD pin, everything else is perfect. And I just tried putting a 5K resistor from TXD to ground just to measure. When I do that I can see pulses on the pin but that doesn't help me when coupling to the radio..
  • ONCE MORE
    since you did not bother to state the whole derivative names
    Your question can not be answered based on generic names.
  • 1. Are the SFRs setup correctly?
    2. If you're looking at the TXD pin there should be activity even if the baudrate is wrong. Why would you connect the load resistor to ground? IF the output is open drain you need a pull up to VDD.
    Happy hunting
  • Hey all,
    thanks for the help.. I'm sorry for the trbl.
    Somehow I was enabling interrupts without an interrupt routine. I still don't know how it worked on the philips.
    Anil
