I am currently using a µvision V5.26.2.0 and sometimes I can't save source file ( h , cpp ).
When it happened the pop ups window showing this message:
"Encountered a sharing violation while accessing {Path to me source file}"
The only one way that can change this behavior is to restart the µvision IDE.
Can I do something else?
Hello All,
You can download the 'MDK v5.27 pre-release' by going to http://www2.keil.com/mdk5/ and
Clicking the "Download MDK v5.27 pre-release" button.
Direct link:
www2.keil.com/.../527pre
This edition should resolve most users issues with sharing violations.
Best regards,
Kevin
"most" ?!
It is called hedging..
What did the underlying issue turn out to be?
I have the same issue and agree with you.
would be interesting to know!
We made were making the IDE more robust, but were checking things in an order that could sometimes cause an issue.
Re-arranging the process that we did that seems to resolve the issue that sparked this thread.
Am using release 5.27 and something similar popped up again.
On recent closure there was an error for saving a header file with error number 22.
Seng Tak
I'm still using an older version. Is this bug now fixed?
Regards, R
Yes, I have not seen it since it was fixed (I'm running 5.27)
Haven't seen the issue crop up in months of use. Using 5.27 currently
This doesn't seem to have anything to do with the rest of this thread?
It does still occur but not as often. I still sometimes get an error stating that uVision is unable to save the file (I don't remember the exact message). I then have to quit the IDE and restart to solve the problem. I have seen this on V5.27 and V5.29.
Same problem. Keil 5.29. Annoying. Fixed or not?
