Hi!
Please tell me from where can I download KEIL uVISION 4 and other older versions if not here on the official website.
Did you not read the reply from R. Kopsch, Posted 28-Aug-2017 14:22 GMT ?
There can be some confusion in Keil product names. Let's try to address them here since this thread is so popular.
Keil Software was its own company.
It was purchased by ARM, and now the software product line is called ArmKeil.
Even after the merger, we still support four different hardware architectures: ARM, C166, 8051, and 251. See: http://www.keil.com/product/
We have a different compiler for each architecture, but we use the same front-end aka GUI aka Integrated Development Environment (IDE) to call the compilers. We call our IDE µVision, also written as uVision. It is pronounced Microvision. See:
http://keil.com/uvision/
We have had major updates to the IDE, so we add a number at the end for each major change. Currently we are using µVision5. Before that, the tools use uVision4. Again, some people write it as uVision4.
... so it is not enough to say you want uVision, you have to say what architecture you want.
To add to that, each Product has different editions, for The MDK development tools, (sometimes also referred to as MDK5 or MDK-ARM) for ARM devices you have 3 editions:
www2.keil.com/.../
The C51 development tools for 8051 devices have 3 editions:
http://www.keil.com/c51/selector.asp
The C166 development tools for C166 devices have 3 editions:
http://www.keil.com/c166/selector.asp
These products can be downloaded from
http://keil.com/demo
... but need a license to unlock the full features.
Downloading older versions of these products requires a valid product license.
On: http://keil.com/demo , Under the "Maintenance Status and Previous Versions" section, paste your Product Serial Number (PSN) or License Code (LIC) into the bluish box and press enter - a list appears of all the versions of your product. Links in blue are versions that came out when you still had valid support.
You can read more about the licensing here: http://www.keil.com/support/man/docs/license/
Starting with MDK v5.12 and later, you can recreate an older version of the Keil tools with the latest version available. It is possible to download the compiler separately, and install it in Keil. For example, this means even thought you are running the latest µVision IDE, you are using the compiler from MDK version 5.14. For more details, see: http://www.keil.com/support/docs/3645.htm
==== Starting with MDK5 and later, you can recreate old project in later versions of the tools. Software is no longer part of the MDK download - libraries and code are now delivered in software packs. For more details, see:
http://keil.com/mdk5
Learn more at http://keil.com/learn
i want to download the software
Have you tried submitting the form provided in the first response?
http://www.keil.com/demo/eval/armv4.htm
Have you tried using Google, pretty sure I could find a direct link there too.
Failing all that contact sales/support using there direct contact methods.
What exactly are you looking for? What have you tried? Why do we get these stupid questions on this thread?
Download KEIL uVision 4 for development software
look more carefully: it's not one person who "just keeps posting" it's a string of different people who keeping dropping in to post the same question.
(well, different usernames, at least...)
Don't download the "KEIL uVision 4" for development software
Instead, download MDK-ARM from http:keil.com/demo
Then download one of the legacy packs from here:
www2.keil.com/.../legacy
... Then you can build a Vision4 project in Keil MDK-ARM version 5.x
Somewhere in its long and inglorious history, this thread has been re-tagged as "C51".
Downloading MDK-ARM is not going to help anyone actually looking for C51 ...
Hi, just want to ask if it is possible to download an eval version of PK51 Professional Developer's Kit that would work in Windows XP.
Thank you.
If the C51 link doesn't yield what you want, then pick up the phone and call the appropriate dept, or local distributors
http://www.keil.com/company/contact/
thank you very much for sharing keil uvision 4
