I'm trying to start a debug session from command line using a different INI file than the one that is selected in the "Options for Target" dialog. The User Manual says:
-d Starts µVision in Debugging Mode. Use this command together with a debug initialization file to execute automated test procedures.
but no mention of an option to specify the debug initialization file is made. So, is there such an option or did I just mistake what's written in the manual?
Thanks in advance for any help.
If you're passing in a project file surely it would have the INI file in the project meta-data, wouldn't it?
project.uvoptx <DebugOpt> ... <tIfile>test.ini</tIfile> ... </DebugOpt>
Of course, but the INI file I'm going to use from command line (for batch testing) is different from the one I use when doing interactive debug in the uVision environment.
I thought I could specify a different INI as an option from the command line (thus overriding the one in the project file) but I guess I was mistaken
