Hello, I'm making use of floating math in my application and have run into a little problem with floating addition. It seems that the floating addition operation looses data at some point. I setup the following test program:
#include <intrins.h> void main(void) { float t, v; unsigned int i; while(1) { // this block uses multiplication for(i=1; i<1000; i++) { t = 5964.1 * i; v = t/i; if(v != 5964.1) _nop_(); } t = 0; // this block will continuously add 5964.1 for(i=1; i<1000; i++) { t += 5964.1; v = t/i; if(v != 5964.1) _nop_(); } } }
"Floating point is the lazy mans way to handle fractions" That what I want to learn!!!Thanks a lot! I'm really a lazy man.
