Hi all, i am working on am small project using 89s52. can anybody please help me with the error in keil.. while compiling i am getting an error in keil...
*** ERROR L105: PUBLIC REFERS TO IGNORED SEGMENT SYMBOL: REEAD SEGMENT: ?DT?SAS_WITH_RTC Program Size: data=136.1 xdata=0 code=4953 Target not created
what does this error mean. how can i get out of this...
now its giving me an error Build target 'Target 1' compiling SAS With RTC.c... SAS WITH RTC.C(1922): error C249: 'DATA': SEGMENT TOO LARGE Target not created what's wrong now...
what are this map files... how can i refer to it.. memory is 256b RAM i am not using any external RAM
Yes - isn't it strange. I also wonder what "'DATA': SEGMENT TOO LARGE" might mean.
Because it can't just be that the DATA segment happens to be too large, now can it???
what can be done now.... i tried changing the memory model from small to large... it complies but cant stimulate in proteus... can you help me out of this
"what are this map files..."
Maybe Google would know what map files are?
Maybe Keil documentation would know what map files are?
"i am not using any external RAM"
The same moment you did switch to large memory model you started to use external memory - you did read up on the meaning on large memory model? You have read up on the different memory areas of the 8051 architecture?
Don't you find it hard to write programs for a tiny microcontroller chip if you don't first spend some time to learn the capabilities of the microcontroller? At least I would not know how to use a new processor without first spending time with datasheets, user manuals and maybe additional architecture documents.
Very good point indeed!
methinks it's bible time www.danlhenry.com/.../80C51_FAM_ARCH_1.pdf www.danlhenry.com/.../80C51_FAM_HARDWARE_1.pdf www.danlhenry.com/.../80C51_FAM_PROG_GUIDE_1.pdf
