why data compressor compress constants in Flash
Hi all, please help me understand data compressor.
I do not understand, why compressor compress the constants in flash.
I believed that only compressed are the data in flash, that are used to initialised variables in ram with a given value. Why even the data in ram are compressed?
But what I do not understand in all, what are my data in flash (const volatile - because can be changed by programing flash from the code in run time).
C++ code:
#define SECTOR_ADDR_for_Config 0x080E0000
const volatile DISTA_konfigurace_flash_typ F __attribute__((at(SECTOR_ADDR_for_Config)))=
{ { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, ..... up to 1024 bytes
MAPFILE: Load Region LR$$.ARM.__AT_0x080E0000 (Base: 0x080e0000, Size: 0x00000400, Max: 0x00000400, ABSOLUTE, COMPRESSED[0x00000190])
Execution Region ER$$.ARM.__AT_0x080E0000 (Base: 0x080e0000, Size: 0x00000400, Max: 0x00000400, ABSOLUTE, UNINIT, COMPRESSED[0x00000190])
Base Addr Size Type Attr Idx E Section Name Object
0x080e0000 0x00000400 Data RW 311 .ARM.__AT_0x080E0000 dista_konfigurace.o
Can anyone help?
Thank you,
Ludek
  • Per,
    when ever I read about volatile:
    publications.gbdirect.co.uk/.../const_and_volatile.html
    en.wikibooks.org/.../C_Programming it mention the prevention from optimalisation.
    Mentioning extern as a cure for that not. So I have to be sure the solution works always from definition for me. Do you have any reference for it?
    thank you,Ludek
  • I didn't bother to look at the second link as a link since I didn't get it tagged as a link.
    The first link doesn't contain any text implying you need volatile - only that volatile is needed where an unknown external part may change the value. That's the asynchronous case where main loop and ISR accesses the same variable. Or two threads. Or the variable is mapped on top of special hardware, like a UART register.
    For non-volatile variables, the compiler assumes they keep the same value until the compiler loses track of the variable - such as when you call a non-inlined function. An exception is if you use extreme global optimization, in which case the compiler may call other functions and because of the global optimizations knows these functions can't change the variable.
    So you do not need volatile when you accesses const data stored in another file.
    But you may get issues if you have code using a const variable value in the same file where you have code:
    const int charlie = 10;
    if (charlie != 10) {
    A newer C++ compiler could in this special case know (based on the language standard) that charlie can't change value. So it can compile the code with the value 10 hardcoded. This because newer C++ can in this case treat const as meaning "can never change"
    If the C++ compiler only knows there _exists_ a const int charlie, then it needs to perform normal variable accesses to charlie. So an update of the flash page will result in the code to behave based on the new value. The code gets generated based on const meaning write-protected for the current code. So no volatile keyword needed - your flash update code will not perform any asynchronous changes.
  • The compiler will only see the actual values when compiling flash_config.c, and will always need to perform memory accesses to pick up the actual values for code in other source files.
    That assessment is no longer universally correct. Link-time optimization is a pretty standard feature of more advanced C and C++ tool chains these days, and that can pick up on cross-module 'const' usages like that. Flagging const objects that can be changed post build-time (e.g. by modifying the final hex file after the fact, or flashing a new copy of the const segment) as "volatile" is standard practice. It's exactly what a developer is supposed to do inform a compiler that a const object's value must always be read from its actual memory, even if the source code itself never modifies it. There's really no excuse for tools not supporting that idiom: it's a language standard requirement.
  • Hans,
    nice to hear, that I am not completely mad. But my knowledge is not bright enought to set linker to work correctly. I am greenhorn regarding scatterfile now. I am even not sure, if I am able to write it in Keil. The variable is Const Volatile placed in Flash. How to set scatterfile entry, that is will be correct and once I use compression of initdata I will not find the compressed data in my variable that is const volatile and is in flash. Do you think it is possible there and now to achieve it just to be sure it will work even in future (or when changing the tools) when, as you write, linker optimalisation could occure. Now I am facing even worse issue that seems is in some relation to const volatile and memory compression functionality that results in hardfault before reaching main when scatterload initialises variables did not correctly sum up the complete image size.. (my observation and guessing).
    thank you for your time and point of view,
    Ludek
    Per, also thank you for discussing and trying to find a solution for me.
  • Is there any one with solution to this case?
    thank you all,
    Ludek
