sfr in xdata
SFRs are declared in the same fashion as other C variables. The only difference is that the data type specified is sfr rather than char or int.
I can't declare sfr to refer xdata. TUSB3210 has some registers there.
  • I can't declare sfr to refer xdata. TUSB3210 has some registers there.
    Yes, but those things in XDATA are not SFRs. They are XDATA mapped registers. Refer to the XBYTE macro.
    Jon
  • But TUSB3210 does have some SFRs in XDATA. I call SFR any non-general-purpose RAM location that programs can manipulate to change operating mode of uC. BTW, The address specification after the equal sign (=) must be a numeric constant.
    (Expressions with operators are not allowed.) Classic 8051 devices support the
    SFR address range 0x80 to 0xFF. The Philips 80C51MX provides an additional
    extended SFR space with the address range 0x180 to 0x1FF.
    How much did Philips pay for thses locations to be SFRs? Actually, I thinked about simpler access to my flags in XDATA and realised that this is not possible for all SFRs.
  • The Philips 80C51MX provides an additional extended SFR space with the address range 0x180 to 0x1FF. How much did Philips pay for thses locations to be SFRs?
    Well, the 8051MX has additional instructions AND additional memory areas. The NEW instructions in the MX are NOT compatible with the legacy 8051 instruction set. Furthermore, the additional SFR memory is not available on legacy 8051 devices. Some of the new instructions provide access to the new SFRs.
    Intel did something similar with the 251. The added new instructions and several new memory areas and lots of new SFRs. They even added 16-bit and 32-bit registers.
    Legacy 8051 devices (which is most of them) only have 128 bytes of SFRs PERIOD. The reason for this limitation is the addressing method. Refer to any good 8051 user guide for more information.
    When a chip is augmented with lots of new instructions and memory areas (like the 8051MX or the 251) a new compiler is required. The cost of developing and testing a new compiler is pretty expensive. But, it's probably not as expensive as designing new silicon and making several new microcontrollers.
    But, I don't think this was the point of your original question.
    Were you finally able to define XDATA registers for the 3210? If not, the following may be helpful:
    #include <absacc.h>
    #define IEPCNFG_0 XBYTE[0xFF80]
    #define IEPBCNT_0 XBYTE[0xFF81]
    #define OEPCNFG_0 XBYTE[0xFF82]
    #define OEPBCNT_0 XBYTE[0xFF83]
    #define INTCFG    XBYTE[0xFF84]
    Jon
