Dear friends,
I am developing an application using keil's RL-USB library to turn the microcontroller into a USB host controller so that I can read a flash memory device.
I am at the very beginning down the road and I want to use the keil's sample for LPC1788 board of embedded artists. the project is located at: C:\Keil_v5\ARM\Boards\Embedded Artists\LPC1788-32 Developers Kit\RL\USB\Host\MSD_File
I have designed my own board (I am not using embedded artists' board) and I have used USB2 as the host controller, not USB 1. Therefore I need to change the HOST controller in USB_Config.c from USB HOST 0 to USB HOST 1. I have done all the programming and everything is fine. There is just one problem that prevents the project from being compiled correctly: .\Obj\MSD_File.axf: Error: L6218E: Undefined symbol usbh1_hcd_ohci (referred from usb_config.o).
It is important to say that the program is compiled successfully when USB HOST 0 is chosen in USB_Config.c. I was wondering if anybody has faced the same problem and solved it before.
"how you solve problem?"
If you had spent a tiny little bit of time reading, you would have noticed how he "solved" it - or in this case figured out the reason for the error.
