debugger question
i am unable to get the port pin toggling in
debugger..
u r answer would be appreciated
chal rao
  • If anyone is able to answer this question, they must be a very accomplished mind-reader.
    Chal, you really need to post some more information, like what exact product you are using, what chip you are simulating, what you are doing to make a port pin toggle, which pin are you trying to toggle, etc.
    I am going to ask the obvious question, is this pin enabled as an output? If it is an input, then you will never see it toggle.
