hello everyone I am trying to use a LCD 20x4 ( 4 bits ) with a lm3s328 , but have not found a proper lib , can someone give me a hand . Thank you .
Have you forgotten to make msTicks volatile? Making done volatile is not necessary because it doesn't get changed elsewhere.
All these variables are declared. As said above , I am studying the systicks , delay ... Below is the code of main.c. Operating at 72Mhz.
Grateful.
#include <stdio.h> #include <stdint.h> #include "../cmsis/device/lpc134x.h" #include "../core/gpio/gpio.h" int main(void) { SystemCoreClockUpdate(); // 72Mhz SysTick_Config(SystemCoreClock / 100); // 1 = 1us / 10 = 1ms / 100 = 10ms / 1000 = 100ms gpioSetDir(GPIO_GPIO1_BASE, GPIO_PIN3, gpioDirection_Output); while (1) { gpioSetValue(GPIO_GPIO1_BASE, GPIO_PIN3, GPIO_PIN3); systickDelay(10000); gpioSetValue(GPIO_GPIO1_BASE, GPIO_PIN3, 0x00); systickDelay(10000); } }
Yes, but as I asked:
If you don't, then it's unlikely to work with an optimizing compiler.
//LCD.c void lcd_delay(int msec) { volatile uint32_t done = msTicks + msec; while (msTicks != done) ; } //LCD.h volatile uint32_t msTicks; //... //VTABLE.c void SysTick_Handler(void) { msTicks++; }
So it would make sense to check whether you're actually executing SysTick_Handler.
