I am currently making a very simple vending machine project which uses the 8051 microcontoller. the pins im using is
sbit C=P3^3; ////// "C" is for coffee/////// sbit T=P3^4; ////// "T" is for tea/////// sbit H=P3^5; ////// "H" is for hot/////// sbit D=P3^6; ////// "D" is for cold/////// sbit S=P3^7; ////// "S" is for purchasing/////
i have done the coding for lcd initialization and selection.. the problem now is that i need the program to run in sequence for example
sequence one: customer should be able to choose only "C" or "T".. (during this sequence all the other pins should be disabled)
sequence two: customer should be able to choose only "H" or "D"..
sequence three: once the above sequence is completed only then customer can press the push button..
The question is how can i disable the other pins at respective sequences.. my code for the selection part is below..
void main () { TMOD=0x02; TH0=0xA4; IE=0x00; L1= L2= 0; a = 0; lcd_ini(); delay(20); lcd_command(0x01); lcd_string("Select Drink"); delay(200); lcd_command(0x01); lcd_string("1.Coffee 2.Tea"); delay(20); flagset=0; TR1 = 0; while (1) { if (C==0) { delay(30); lcd_command(0x01); lcd_string("Coffee: Hot/Cold"); } if (T==0) { delay(30); lcd_command(0x01); lcd_string("Tea: Hot/Cold"); } if (H==0) { delay(30); lcd_command(0x01); lcd_string("Hot Selected"); } if (D==0) { delay(30); lcd_command(0x01); lcd_string("Cold Selected"); } if (M1==0) { delay(30); b++; switch(b) {case 1: lcd_command(0x01); lcd_string("RM 1.00 Inserted"); delay(20); break; case 2: lcd_command(0x01); lcd_string("RM 2.00 Inserted"); delay(20); break; case 3: lcd_command(0x01); lcd_string("Insert Money"); if (b==3) {b=0;}} } if (S==0) { lcd_command(0x01); lcd_command(0x80); lcd_string("Processing"); delay(100); lcd_command(0x01); lcd_command(0x80); lcd_string("Please wait"); L1 = 1; delay(100); L1 = 0; ///////L1 and L2 is for lights/////// L2 = 1; lcd_command(0x01); lcd_command(0x80); lcd_string("Remove drink"); delay(100); L2 = 0; lcd_command(0x01); lcd_command(0x85); lcd_string("Thankyou"); delay (500); } } }
thank you in advance
Then the compiler will complain about lvalue if you accidentally write an assign. Getting a compilation error instead of a warning is good. by my philosophy there is no difference between errors and (unintended) warnings.
Intended warning: a warning that is a result of some (later removed) test
Absolutely. In my book a warning should be treated as an error unless proven otherwise.
But an error has the advantage that it results in a build failure. While a warning may always tempt someone to ignore, or add a one-time excemption or maybe totally turn off one specific message.
Would highly recommend enabling the option "treat warnings as errors". If someone is hell bent on removing an error, they could just swap over the constant and enumerator.
It's always difficult to successfully predict what an idiot programmer is capable of doing.
Unfortunately, I have witnessed such thinking. And at least once from someone who was considered to be competent engineer!
'someone' may be an idiot 'someone' may not.
I know that a lot of 'modern tools' put a large emphasis towards protecting idiots from doing idiotic things, but the best method still is not to ask an idiot to do the job.
