so i explain. the application is very conplicated. atm it got 223 tasks but it will get more. ride51 has the code compresser. does uvision? i mean i want each task uncompress when it runs. how? wait for the reply now.
so i did waste some time with your suggestions. but it is obviously no good for my project. i said first it is very conplicated. you probably cannot understand.
dont waste any more of my time to answering the distractions. i see you want to show you are better. but wait.
Go, go away. Please. __SNIFF__
Yes, I'll eagerly wait for the 223 code-compressed threads to run in the marvelous 8051 processor some companies uses as keyboard or mouse controller.
you better use the acme ACM8051 which comes in a rubber case.
PS what Raisonance cals "code compressor" Keil calls "optimize"
There's absolutely nothing obvious about that. That's because a) you haven't told us nearly enough about the actual project for anyone to know what could possibly be obvious about it, and b) your assessment of your own work is most probably wrong.
Or maybe we simply refuse to believe you, because there's no particular reason we should. There are two reasonably likely possiblities at this point: either
1) you really don't know what you're talking about, or
2) a '51 is entirely the wrong choice of platform for your project
The only person who can waste any of your time is you. And given you insisted you were so terribly busy, you're certainly doing an awful lot of that.
so it is obvious to me. and it is me who is doing this work not you. all everyone said here was a waste of my precious or valuable time. and so your asessment is obviously wrong. the 3rd posibility is i a right and you dont understand. you didnt even think of that did you! you think you know so much about my project. how? you hack my computer? i did not tell you even what it is and you who know nothing in the facts. you say i am wrong. you know what i have for lunch? you will be wrong again. you do not know. why do you try to slow me with the time wasting questions. you will not answer i refuse to answer any more of the time wasting tactics.
I WILL NOT SHOW YOU MY GODE. COODBYE.
I'd say you had fish for your lunch.
Am I right?
That is EXACTLY the point since "it is me who is doing this work" of course "it is obvious to me"
HOWEVER
all your posts have assumed that it is obvious to us as well.
with the skimpy descriptions you have given it is BY NO MEANS "obvious to us"
You are not the first posting here assuming that you are communicating with mindreaders
That's flat-out impossible. Writing here consumes only one person's time: the one writing. As I said here before: the only one wasting your time here is you.
And you do so largely by believing your own illusions of grandeur more than the people trying to correct you. Since you're so immune to advice, and even proud of that: by all means don't let anyone keep you from running into that concrete wall at your own speed. Be prepared for a resounding chorus of "We told you so!", though.
If you knew how to read, you might have noticed I was listing "reasonably likely" possibilities. That one isn't.
I challenge you to explain how you arrived at that conclusion from my posting. Go ahead, try.
you say i am wrong.
Once again you fail at the rather basic skill of reading. I said you were probably wrong when you assessed your own work. And since just about everybody on this world regularly is, that's a pretty safe bet.
... and again, you failed to read. I asked no question.
And you seriously believed that would be a shocking disappointment to us, don't you? No, please don't answer that.
