i am facing a wierd problem.. My MCU P89V51RD2BN resets during Execution... i am a college student and a beginner Here so i dont know the Advanced Programming methods i would also inform that..
i have a recursive function , a warning is issued by the compiler for the same. but....
earlier this was not a problem but since i have modified some of the Sub-Routines for 16Bit Data this Problem has come up, i need those functions to be 16 bit because of the limitation of the ALU i was earlier using 8bit and leaving most of the Task to Assumption which i cannot do so now..
i would also state that the Problem occurs in a fumction at a point when i call 2 functions in the same code, these themselves call around 5 sub-routines each but that wasnt a problem earlier (before i used the 16bit return type sub-routines).
now i found something in the manual stating reentrant Functions, but i really dont know how to use it
i used it like this
void Home_Screen_Instance() reentrant { ------------ } Do i need to use the keyword "reentrant" in the Function Decleration too? but that didnt help either but the compilers shows an error Home_Screen_Instance : redefinition. Target Not Created
this was the first of a kind problem that i encountered, my MCU is resetting itself for sure(i checked that with a dummy subroutine of blinking LED) and it is not because of the watchdog timer, i am sure about that too..
so whats the Problem here?
is the Stack overflowing??? or there is any other reason behind this? should i revert back to the 8bit versions of my subroutine (without any other choice)? is it because of the recursive nature of the function H0me_screen_instance?
Related Data:
The Program is Display intensive, i mean there are a lot of Strings to be displayed and they are stored beforehand in XDATA, message shown during sucessfull compilation, (still resets) Program Size: data 9.4 xdata 252 code 9514 creating hex-----blah blah blah---- 0 Error(s) 65 Warning(s)
"wrong whether embedded or not, it is just bad design"
It's more interesting than that. What if the second stacked main menu also gets a timeout and locks the screen. Or the 100th nested call to the main menu? Then we have the situation: menu -> lock -> menu -> lock -> menu -> lock -> ....
Any processor with a finite state storage area would run out of state space (wither a hw stack or a software-implemented stack) for such a design.
Any processor with a finite state storage area would run out of state space (wither a hw stack or a software-implemented stack) for such a design. I have actually seen that one, a frustrated used pressing the button umpteen times and SPLASH!
i am completely new to embedded C Programming.
You're still evading the real issue. You're quite clearly new not just to embedded programming, nor just to C programming, much less embedded C programming. It's becoming increasingly clear that you're completely new to programming, period.
In other words: you're clearly in way over your head. So stop right there, take several steps back and re-think your strategy from there. Learn some fundamentals, e.g.: "What is unbounded recursion, and why should one never allow it to occur in a program?" or "What is a finite state machine?" before you come back to this project.
Thanks for your Advice.... I'll seriously consider implementing them... i know i am not good at programming... thanks for your comments, i shall now have a new approach towards programming
i shall now have a new approach towards programming the while thing: Keep It Simple, Stupid processing interrupts: Keep ISRs Short and Simple
All Recursions Gone now !!! Thanks erik and others.. i just couldnt come up with such a thing..
now i have different "Draw Functions" and input Functions and they are not Recursive or forming any kind of chain...
one question though..
at one point i need the user to enter a number whose length (number of Digits) would be decided by me during the coding phase, i am thinking of implementing it in the form of a stack, so that i would know if he entered all the digits or not.. am i doing it right?
Ex: i need the user to enter a 4 digit number, so i am using a stack but if the user enters a three digit number, i break out of the Keypad_Input function and based on the position of the "StackTop" i find the final values. if user enters 999 Stack top is at 3 so the number is 9*10^2+9*10^1+9*10^0 if user enters just 9 stack top will be at 1 so the number is 9*10^0
void Keypad_Instance(ubit_8 Size,ubit_8 line,ubit_8 pos,bit show,ubit_8 BreakC) { ubit_8 Keypress; //Temproary variable to store the key pressed Stack_Initialize(); //initialize the stack, makes all character NULL Keypress= False; LCD_Cursor_XY(line,pos); //Move cursor to desired position while(!Check_Overflow(Size)) // when Function return False i.e no Overflow { while (!Keypress) //Show a Blank Character if nothing is pressed { LCD_Cursor_XY(line,pos); LCD_Data(0xFF); Keypress = Keypad_Input(); } if(Keypress != False) { if(Keypress >= '0' && Keypress <='9')//if a number is pressed { Stack[Stack_Top] = Keypress; ++Stack_Top; if(show == 1)//when not using this function for password { LCD_Cursor_XY(line,pos); LCD_Data(Keypress); pos=pos+1; } else //when using this function for password { LCD_Cursor_XY(line,pos); LCD_Data(0xFF); pos=pos+1; } } else if(Keypress == BreakC) // Character to break out the "Cancel" Button { Break =1; // Notifies that user cancelled the procedure return; } else if (Keypress == 'B') //Backspace key { if(Stack_Top == 0) //Underflow Condition, cannot pop out more { continue; } else { LCD_Cursor_XY(line,pos); //Move Cursor From Curent Position LCD_Data('\0'); pos=pos-1; LCD_Cursor_XY(line,pos); // delete Previous Character; LCD_Data(0xFF); --Stack_Top; // POP Character from Stack. } } /* when user enters less characters than the maximum limit 'A' is placed at stack top, this is used when calulating the final numerical value from the Character inputs obtained from the user*/ else if (Keypress == 'A') { Stack[Stack_Top] =Keypress; ++Stack_Top; break; } Keypress = False; // Get Keypress ready for the next character. Delay200ms(); //Give a delay for the user to enter the character (Debounce) } } --Stack_Top; //To point at the last stored position }
need comment about the code... any improvements on this?
ubit_8 is unsigned char and the Stack_Initialize() function gets the stack ready for input..
the Size of the stack is 10Bytes, and i initialize each location with a 'Null Chracter" while initializing it, i have now changed the function to initialize only desired number of characters with a "null character" before getting the input from the user.
You take as parameter what character that represents a break?
But you use a global parameter for telling that your function was exited by a press of a break character.
I would have thought that the break character was a constant.
And that the return value from function would tell if data entered or cancel.
The Character 'C' on my Keypad is the Break Character Character 'B' Behaves as Backspace Key Character 'A' is used when the user is done entering the values less than the maximum limit ex: i have set a limit of 4 characters so maximum value is 9999 but he user wishes to enter just 99 then he presses 9->9->'A'
a global bit variable 'Break' is used to notify that a user initiated break has occured and the system comes back to a state before the user input was requested.
Yes, but my question is why you used it as a configurable key - why a parameter to the function.
When designing a user interface, it is normally very consistent which key is escape and which key is enter.
Next thing - why a stack?
You can just compute a numeric value as you go - only keep track of number of digits.
if (num_digit < 4) { num *= 10; num + digit; num_digits++; }
or for delete:
if (num_digits) { num /= 10; // integer division strips last (least significant) digit. --num_digits; }
Then return a value 0..9999 for valid input, and -1 if user cancels the input.
i was passing Parameters to the function because at some places The Space available at the LCD is limited its like XXXXXW 'X'is the available space for user input while the rest has been occupied by other text, so if the input is unbound in terms of number of digits it may overwrite, other strings on the LCD.
Secondly, one of the parameters is "bit show" which is used to control if the characters being typed need to be visible at the LCD.
i had doubts implementing it as a stack...but my main reason was the unknown Size(number of Characters) for the input, that's why i let it be a stack of 10 Characters, so that the same stack can be used if i made some other Sub-Routine which required Stack implementation.
and one more question... i was searching for books on Programming both general Programming and Embedded Programming and of these the best i found was Embedded C by Micheal J Pont The art of Programming by Knuth
can you suggest any other reads apart from these.. the book by muhaamad ali mazidi is one of my textbook
I do know what you used the parameters for.
But the interesting question is why you think you need the parameter "BreakC".
yeah... i didnt realize that was actually taking extra work all the time, i really didnt require BreakC... ill define a constant for that, it would atleast reduce the number of parameters
here i got another problem, the code in between the Stars is being bypassed completely, i didnt understand it first but then i started inserting dummy routines in between codes and found out that the code (in Bold) is being completely bypassed every time.
Home_Screen() //Draws the Home Screen Keypad_Instance() //Has been already posted in this thread Check_Lock1() //Checks if the code entered is correct or not and opens the lock if true
void Start() { Lock_State = Closed; do { Home_Screen(); while(Keypad_Input() == False);// Wait for a key to be pressed. //******************************************************************************************* while(Lock_State == Closed) { Lock_Screen(); Keypad_Instance(5,2,8,0,'C'); // 5 character password at pos 2,8, Hidden and 'C' is the break Character Check_Lock1(); //Check the Password, if true then Lock_State=Open if(Lock_State == Open)// Lock is Open break; else { LCD_Cursor_XY(3,7); LCD_Text("RETRY !!!"); //on entering Wrong Password } } Main_Menu1_Instance(); //********************************************************************************************* }while(1); }
i didnt get it, why is this not working, Note: i tried implemnting the Code in italics in a do-While loop, but the same problem creeped up, this was not a problem when i had those recursive functions LOL ;P!!
what if i have to enter a 4 digit number, 9999 the maximum value i permit in this project as an user input can be contained by an unsigned int variable.. suggestions:
if (num_digit <= 4) { num *= 10; num + digit; num_digits++; }
or
if (num_digit <= 5 && Stack[0]<7) // im using a stack here,first element (MSB) is always at Stack[0] { num *= 10; num + digit; num_digits++; }
will this be fine?
also i suggest we do it at the end.. when the user has completed entering all the details, well it depends upon the number of characters being entered... yours look really good if the number of characters is large more than 5... i modified your code
unsigned int Temp2=0; while(Size>0) //Stack begins at 0, but Size is a natural Number { Temp2*=10; Temp2+=Stack[Stack_Top - Size]-'0'; //Stack_Top is at Size after the Execution --Size; }
now if the user is done with just one digit or two and i separately need to know that then Temp2%10 or Temp2%100 or like that..
what you are trying to overcomplicate has been done in very simple ways many, many times before.
