I am trying to pass a pointer by reference to a function and get that function to point my pointer at a structure that it finds.
char get_structure(STRUCTURE **ptr) { if(foundstructure) { *ptr = &theStructure; return 1; } return 0; }
This works how I expect it, but when I try and declare the function prototype in the header file:
char get_structure(STRUCTURE **ptr);
I always get a compiler error:
error C141: syntax error near '*', expected ')'
I don't get an error when this is a defined type like char, int or long, but I get the error when this is a pointer to a typedef that I have defined.
How can I declare this in my header file without an error?
Nathan
I know it's not the structure that is the problem. This structure has been used in it's current state for over a year now in many implementations. It is only the double pointer in the prototype that is causing grief.
Actually, no, it's not. If you put that exact code into (minus the syntax error '...', and plus a typedef for uint8) into an empty file, and compile that, it works just fine and dandy (uV4, C51 9.02). Which goes to show that whatever the problem actually is, it's not what you claim it is.
So, next try: show an actual, self-contained example that demonstrates the error.
In that case, you'd still to have to give them something to try!
Specifically, You'd have to give them a minimal but complete example that demonstrates the issue. You should be able to do that with non-confidential code. And you could share that on the foum.
I seem to be dealing with an include/linker error. The structure is not defined at that point in the header file. I was sure I tested this by declaring the parameter by value and by reference, and the error would only show up by pointer reference (double pointer). Since yesterday I updated to 9.05 an now all 3 are returning the C141 error. The forward declaration as someone mentioned doesn't work though... will post again when I've solved this.
main.c:
#include "struct.h" #include "function.c" STRUCTURE *structPtr; void main(void) { while(1) { get_struct(&structPtr); } return; }
struct.h:
#ifndef __STRUCT_H #define __STRUCT_H #include "function.h" typedef union _STRUCTURE { unsigned char fields[2]; struct _NAMED { unsigned char field1; unsigned char field2; } NAMED; } STRUCTURE; #endif
function.h
#ifndef __FUNCTION_H #define __FUNCTION_H void get_struct(STRUCTURE **myStruct); #endif
function.c
#ifndef __FUNCTION_C #define __FUNCTION_C #include "struct.h" #include "function.h" STRUCTURE myStruct; void get_struct(STRUCTURE **strPtr) { *strPtr = &myStruct; } #endif
As you can see my problem is that I have a circular header reference "struct.h" includes "function.h" and "function.h" includes "struct.h". The example doesn't show it, but "struct.h" needs to include "function.h" because there is an enum declared in "function.h" that is part of the structure in "struct.h". I believe this can be solved using forward declarations, but I have not had any success yet.
So maybe:
#ifndef __FUNCTION_H #define __FUNCTION_H void get_struct(union _STRUCTURE **myStruct); #endif
By the way - from the first response you got to your issue: "Have you made sure that STRUCTURE is defined at that point in the header file?"
Including .c source files is almost always the wrong thing to do.
main.c should include function.h, not function.c. struct.h is not dependent upon function.h, so should not include function.h. function.h is dependent upon struct.h to fully publish get_struct()'s interface, so should include struct.h. function.c should not be included by anything, so does not need include guards, and needs to be added to the project's list of .c source files for separate compilation and linking.
I mentioned in my post that although the example doesn't show it, struct.h does depend on function.h. There is an enum that is declared in function.h that is used in STRUCTURE.
Revised Example:
#ifndef __STRUCT_H #define __STRUCT_H #include "function.h" typedef union _STRUCTURE { unsigned char fields[2]; struct _NAMED { unsigned char field1; ENUMERATION field2; } NAMED; } STRUCTURE; #endif
function.h:
#ifndef __FUNCTION_H #define __FUNCTION_H typedef enum _ENUMERATION { ONE = 1, TWO = 2 } ENUMERATION; void get_struct(STRUCTURE **myStruct); #endif
function.c:
Adding function.c to the project and changing the include to function.h instead of function.c did not solve the problem.
Thanks very much. This solved the issue. Is there a term used for this type of reference?
Also I'm positive that I was getting no such error in V9.01 when making reference to STRUCTURE except when used in the double pointer scenario.
char get_structure(STRUCTURE *ptr); // == NO ERROR char get_structure(STRUCTURE **ptr); // == ERROR EVERY TIME char get_structure(char **ptr); // == NO ERROR
After the update I could make no reference to STRUCTURE without an error being thrown.
"Adding function.c to the project and changing the include to function.h instead of function.c did not solve the problem."
Had you followed all the instructions, you would have seen that it solved the problem in the code you posted.
"I mentioned in my post that although the example doesn't show it, struct.h does depend on function.h. There is an enum that is declared in function.h that is used in STRUCTURE."
Making your first example a waste of time. Now that you've posted a complete example demonstrating your problem, I've made a few small edits:
main.c should include function.h, not function.c. function.h is dependent upon struct.h to fully publish get_struct()'s interface, so should include struct.h. function.c should not be included by anything, so does not need include guards, and needs to be added to the project's list of .c source files for separate compilation and linking.
#include "struct.h" #include "function.h" STRUCTURE *structPtr; void main(void) { while(1) { get_struct(&structPtr); } return; }
#ifndef __FUNCTION_H #define __FUNCTION_H typedef enum _ENUMERATION { ONE = 1, TWO = 2 } ENUMERATION; #include "struct.h" void get_struct(union _STRUCTURE **myStruct); #endif
One sidenote is that your use of identifiers with leading underscores risks treading on the implementor's reserved namespace.
Duly noted, but those edits do not fix the problem either. Compiler is still throwing the C141 error. Only if I declare the prototype like this do I avoid the error:
"Only if I declare the prototype like this do I avoid the error:
And the prototype in the function.h I posted is:
How do they differ?
Sorry, I thought you were offering a solution to solve the problem.
Thanks again to Per Westermark.
"Sorry, I thought you were offering a solution to solve the problem."
Oh, good grief!
*plonk*
Circular dependencies are a design bug in your software. You must resolve that.
Generally speaking, when you can't decide whether "a.h" should include "b.h" or the other way round, that's a strong indication that your design is wrong, and you should really have only one header holding the combined content of both "a.h" and "b.h".
Then the definition of that enum should not be in "function.h". It belongs into "struct.h".
I recommend you spend some time with the C language standard. The use of "struct <structname>*" is specifically allowed to be used before the full description of the structure is seen just to avoid problems with circular references.
The thing is that a struct <structname>* is a pointer of known size - as long as you don't try to follow that pointer, you don't need to know how large the struct is, or what member fields it has. If we ignore the issue with specific addressable memory regions in the 8051 processor architecture, or memory models with small/medium/large/huge/... pointers, the size of a pointer to struct is the same what ever the type the struct has. And the word "struct" or "union" before the tag name is enough that the compiler understands that the tag name is the name of a structure or union type. Just seeing "STRUCTURE", the compiler don't know it's one of your own data types. And it's not a known keyword. So the compiler don't know what to do. Your code as written is invalid C code. And the compiler did complain.
