USB HOST problem during array write
Hi
I want to send an array of data to a USB pen drive using LPC1768.
and USBhostlite code is available here:
>ics.nxp.com/.../
and I removed Uart from codes so that it just copies data to usb.
the codes that i modified are:
void Main_Write(void){
        USB_INT32S  fdw;
        USB_INT32U  bytes_read;
        char  temp[8];
        USB_INT08U  temp_buf[504]={0};
        int i,j={0};
        bytes_read=9;
        fdw = FILE_Open(FILENAME_W, RDWR);
        if (fdw>0) {
                        do{
                                sprintf(temp,"%d",bytes_read);
                                for (j=0;j<9;j++){
                                        temp_buf [i]=(temp[j]);
                                        i++;
                                temp_buf [i]=0xA;
                                i++;
                                bytes_read ++;
                        }while(i<=504);
                        FILE_Write(fdw,temp_buf,504);
                        FILE_Close(fdw);
                }else{
                        return;
sprintf converts bytes_read to ascii codes then it is sent to temp_buf using a do{...}while() then an "MSWRITE.TXT" file is created in usb disk and finally the buffer will be written to the usb disk.
these codes work properly, when size of the buffer(temp_buf) is less than "90". but when i change the buffer size to a bigger number(eg: 504), the program doesn't work!
it even doesn't creates any empty text file(due to file_open)
i traced file_open routine and i found that the problem is in MS_BulkRecv routine. because the program runs before calling MS_BulkRecv and halts during calling this line. this routine is as follows:
*                                         RECEIVE THE BULK DATA
* Description: This function is used to receive the bulk data
* Arguments  : None
* Returns    : OK                             if Success
*              ERR_INVALID_BOOTSIG    if Failed
USB_INT32S  MS_BulkRecv (          USB_INT32U   block_number,
                                   USB_INT16U   num_blocks,
                         volatile  USB_INT08U  *user_buffer)
    USB_INT32S  rc;
    int i;
    volatile USB_INT08U *c = user_buffer;
    for (i=0;i<MS_BlkSize*num_blocks;i++)
        *c++ = 0;
    Fill_MSCommand(block_number, MS_BlkSize, num_blocks, MS_DATA_DIR_IN, SCSI_CMD_READ_10, 10);
    rc = Host_ProcessTD(EDBulkOut, TD_OUT, TDBuffer, CBW_SIZE);
    if (rc == OK) {
        rc = Host_ProcessTD(EDBulkIn, TD_IN, user_buffer, MS_BlkSize * num_blocks);
        if (rc == OK) {
                rc = Host_ProcessTD(EDBulkIn, TD_IN, TDBuffer, CSW_SIZE);
            if (rc == OK) {
                if (TDBuffer[12] != 0) {
                    rc = ERR_MS_CMD_FAILED;
    return (rc);
can any body tell me why this increase in buffer size causes the program not to work? and help me to solve it?
thanks
Amir
  • So you decided to do random "fixes" instead of trying to understand the code. Is that really a good methodology? Will it give you any advantages when you write your next program?
  • No!
    It is Crystal clear that i must improve my c language and remember what I have Learnt many years ago and have forgotten it already, But I didn't solved it by TRY and ERROR!
    Just one of my Friends Helped me with this! and told me that probably the problem comes from stack.
    Best Regards
    Amir
  • So not you, but your friend, solved it by trial and error then. Or why else the "probably comes from stack"? How many minutes would it have taken to verify if that was true or not?
    Bugs shouldn't be fixed until you know _why_ they are bugs. And if the problem you see can be explained by that bug. Else, you will not know if the code changes fixes the bug or just (temporarily) hides the bug - or moves the problem somewhere else.
    There is nothing "probable" about the amount of stack space needed for:
    So - did your program have room for that variable on the stack or not? Making it into a global variable means it consumes RAM all the time. Having it on the stack means the stack must be large enough. But that the same RAM can be used for other auto variables in other call trees too.
    Of course there are other differences between auto and global variables: If you take the address of an auto variable and uses that address after the function returns, you can get very nice problems.
