#include<regx52.h> #include<lcddisplay.h> #include<UART_gsm.h> #include<string.h> #include<intrins.h> #include<stdlib.h>
sbit buz = P2^7;
sbit gsm = P3^2; sbit board = P3^3;
data unsigned char mobilenum[10]; data unsigned char msg[80]; unsigned char XX,newmsg=0,j=0;
void readmsg(void);
void serintr(void) interrupt 4 { if(RI==1) { XX=SBUF;
if(XX=='+') newmsg=1; j=j+1;
if(j>100) j=0;
RI=0; } }
void delay(unsigned int); void main() {
lcd_init(); UART_init(); lcdcmd(0x85);
board=1; gsm=0; RI=0;
lcdcmd(0x01); msgdisplay("searching for"); lcdcmd(0xc0); msgdisplay("GSM modem"); delay(300); send_to_modem("ate0"); //to avoid echo signals, enter(); again: send_to_modem("at"); // TO CHECKING GSM MODEM... enter(); delay(50); if(!RI) // Here we are waiting for data whitch is sending by GSM modem goto again;
RI=0; EA=1; ES=1; lcdcmd(0x01); msgdisplay("SYSTEM"); lcdcmd(0xc3); msgdisplay("CONNECTED"); delay(100); send_to_modem("at+creg=0"); // enter(); delay(300); newmsg=0;
xxx: lcdcmd(0x01); msgdisplay("CHEKING SIM"); send_to_modem("AT+CPIN?"); // enter(); delay(500); if(newmsg==0) goto xxx; buz=0; lcdcmd(0xC0); msgdisplay("SIM CONNECTED"); delay(500);
send_to_modem("at+cmgf=1"); // tr set message format astext mode enter();
send_to_modem("at+cmgd=1"); //delete the message1 enter(); delay(500); send_to_modem("at+cmgd=2"); //delete the message1 enter(); ES=1;
st: delay(1000); buz=1;
while(RI==1) { RI=0; delay(100); }
RI=0; lcdcmd(0x01); msgdisplay("GSM NOTICE BOARD"); lcdcmd(0xc0); msgdisplay("SYSTEM"); ES=1; delay(500); newmsg=0; while(newmsg==0); ES=0; //delay(500); readmsg();
ES=1; delay(500); ES=0; TR1=0; board=0; gsm=1; TR1=1; buz=0; msgdisplay(msg); delay(500);
ES=1; delay(500); enter(); delay(50); j=0; resend:
ch_send_to_modem(35); j=0; delay(500); if(j==0) { enter(); delay(50); goto resend; } while(j<50); lcdcmd(0x01); msgdisplay("Updating Message"); lcdcmd(0xc0); msgdisplay("1 "); delay(1000); ch_send_to_modem('3'); j=0; while(j<25); msgdisplay("2 "); delay(750); ch_send_to_modem('5'); delay(750); ch_send_to_modem(42); j=0; while(j<10); msgdisplay("3 "); delay(2000); ES=0; send_to_modem("<M "); send_to_modem(msg);
send_to_modem("><S 1><D L1><T 1>"); enter(); j=0; delay(1000); lcdcmd(1); buz=1; TR1=0; board=1; gsm=0; TR1=1; delay(500); send_to_modem("at+cmgs="); ch_send_to_modem('"'); send_to_modem(mobilenum); ch_send_to_modem('"'); enter(); delay(50); send_to_modem("MESSAGE UPDATED SUCCESSFULLY"); ch_send_to_modem(0x1a); ES=1; delay(500); lcdcmd(0x01); msgdisplay("MESSAGE SENT");
delay(3000); goto st; }
void readmsg(void) { unsigned char a,b,i,count,numcnt;
delay(100); ES=1; delay(300); ES=0;
lcdcmd(0x01); send_to_modem("at+cmgr=1"); enter();
count=0; i=0; a=0; numcnt=0;
while(count!=3) { while(RI==0); b=SBUF; if((b==',')||(a==1)) { if(numcnt<15) { if(numcnt>4) { mobilenum[numcnt-5]=b;
} a=1; numcnt++; } else a=0; } if(count==2) { msg[i++]=SBUF; }
RI=0; if(b==10) count+=1; }
msg[--i]='\0'; msg[--i]='\0'; mobilenum[10]='\0'; send_to_modem("at+cmgd=1"); enter();
Even MISRA C accepts the GOTO in forward references within a code block. makes no sense MISRA C outlaws 'return' in the middle of a function.
so ... return; // my favorite 'goto' ....
is illegal
but
... goto exit // a 'goto' that depends on a properly located label ...
is legal
