Non allocatable reset of NXP LPC2368 using RTX when modifiing variables
Hello everyone,
today I'm asking for hints on a tricky problem. We have a firmware that uses RTX-Kernel running on a NXP LPC2368. Now the device that the firmware is written for should get a new lc display.
My honest mission is to change the firmware in order to use the new display.
I've spent some weeks this year to do so and some time I've had the problem that the controller resets short time after start and again and again...
Everytime this behaviour occured I have deleted one or more obsolete variables (mostly global) or functions. In most cases I solved the problem by searching other obsolete variables and deleting them from source code - try and error. That is really time-killing.
While testing the firmware on wednesday, I tried to make the adopted and modified routine for writing data to display RAM a little faster. I moved an global unsigned int to the function and changed it to static unsigned char because the value it has to carry is 0x0D at a maximum.
After flashing the firmware in the controller, the controller hung at a random short time.
Yesterday I was trying to solve the problem with hanging firmware on random time and found the problem when no task is running: OS calls os_idle_demon() and was not able to return from it. I found a solution in world wide web: Creating an empty low priority task without using any os_wait functions that prevents the OS from calling the idle task. (It has something to do with incorrect interrupt states on retunring from idle task.)
Today I further tried to make the display writing function faster and changed two unsigned char inside the function from static to non-static. After flashing this firmware the controller resets again and again. I will now try to find out why the controller behaves this way.
What I found out is, that no watchdog is enabled by user (is it part of the OS?). The os_stk_overflow an os_idle_demon are not called from OS. I debug the firmware using ULINK2.
Any ideas where to search the problem for?
Best regards
  • Interrupts _must_ be disabled while servicing the watchdog !
    Use
    __disable_irq() ;
  • Or, even better - make the servicing function a SWI function.
  • *AAAARRRGGGHHH*
    I read about disabling interrupts... LPC23xx user manual:
    "Interrupts should be disabled during the feed sequence. An abort condition will occur if an interrupt happens during the feed sequence."
    Why don't they mark such important sentences with an exclamation mark in their user manuals?
    Thank you for helping out immediately Tamir!
    PS: I will re-read the insiders guide to check if I am able to implement the feeding of the predator via SWI function.
  • I implemented kicking the watchdog as an swi function first called in task1:
    // project.h:
    extern void __swi(12) WDT_KICK(void);   // RoS| 15.12.2011: feeds the watchdog
    // watchdog kicking and initialization (in project.c):
    void __SWI_12 (void)
            WDFEED= 0xAA;
            WDFEED= 0x55;
    __task void task1(void)
      WDCLKSEL= 0x00000001;
      WDTC= 0x00000FFF;
      WDMOD= 0x03;
      WDT_KICK();                           // <= execution STILL jumps to DAbt_Handler in startup file?
    int main(void)
      os_sys_init_user(task1, 1, &id1_stk, sizeof(id1_stk));
    // SWI_Table.s:
    ; Import user SWI functions here.
      IMPORT  __SWI_8
      IMPORT  __SWI_9
      IMPORT  __SWI_10
      IMPORT  __SWI_11
      IMPORT  __SWI_12
      EXPORT  SWI_Table
    SWI_Table
      DCD     __SWI_0                 ; SWI 0 used by RTL
      DCD     __SWI_1                 ; SWI 1 used by RTL
      DCD     __SWI_2                 ; SWI 2 used by RTL
      DCD     __SWI_3                 ; SWI 3 used by RTL
      DCD     __SWI_4                 ; SWI 4 used by RTL
      DCD     __SWI_5                 ; SWI 5 used by RTL
      DCD     __SWI_6                 ; SWI 6 used by RTL
      DCD     __SWI_7                 ; SWI 7 used by RTL
    ; Insert user SWI functions here. SWI 0..7 are used by RTL Kernel.
      DCD     __SWI_8                 ; SWI 8  User Function
      DCD     __SWI_9                 ; SWI 9  User Function
      DCD     __SWI_10                ; SWI 10 User Function
      DCD     __SWI_11                ; SWI 11
      DCD     __SWI_12                ; SWI 12 User function - Kick Watchdog with interrupts disabled (except FIQ)
    The device resets again and again... It still jumps to DAbt_Handler when executing WDFEED= 0xAA;...
    Since there is no FIQ used, I have no idea why this is not working! :(
    Could this have something to do with the RealTime Agent?
