For ARM7, A hardware timer is 32-bits, and unsigned int is 32-bits too; For a 16-bits MCU, A hardware timer is 16-bits, and unsigned int is 16-bits too;
So,
t0 = timer_val; while ( ( timer_val - t0 ) < delay_val );
provide a simple and good delay;
Not so sure about, if a cast is needed.
t0 = timer_val; while ( (unsigned int)( timer_val - t0 ) < delay_val );
Just noticed that, due to the integral promotion,
unsigned short t0, t1; ( t1 - t0 ) is a signed int.
It seems that,
unsigned int t0, t1; ( t1 - t0 ) is still an unsigned int.
I noticed this, because I use unsigned short to present a 16-bits timer_val on my X86-PC for testing/simulating purpose, and the result is not what I expected.
I realize the below is a quite stupid question, but
Is it possible that,
#define LWIP_U32_DIFF(a, b) (((a) >= (b)) ? ((a) - (b)) : (((a) + ((b) ^ 0xFFFFFFFF) + 1)))
this macro is designed for a 64-bits system, so that a cast is not necessary?
that's nothing else but (a - b)
My understanding is that the author is trying to avoid subtracting unsigned integers with an overflow (or is it underfow?) If you can point me to the exact place in the C standard where it describes the behavior of unsigned integer underflow, I would be grateful. All I could find is this:
A computation involving unsigned operands can never overlow, because a result that cannot be represented by the resulting unsigned integer type is reduced modulo the number that is one greater than the largest value that can be represented by the resulting type.
As far as I understand this, it applies to addition. I'm not so sure about subtraction. But English is not my first language, maybe I'm missing something?
I have no idea how you could possibly have arrived at that understanding. Addition isn't even mentioned in that excerpt from the standard, nor was it taken from the section about the '+' operator: it's from C99 6.2.5 "Types", paragraph 9. Do you really think the Standard authors would have written "A computation" if they had meant "An addition"?
Yes, I do. Computations that could lead to an overfow include addition and multiplication. Please stop being so negative for a minute. Help me find the place in the standard where it describes the behavior of unsigned integer overflow and underflow during addition and subtraction.
Just try to provide some information (may be useless), sorry for any of my improper behaviors.
www.securecoding.cert.org/.../INT30-C. Ensure that unsigned integer operations do not wrap
According to C99, Section 6.2.5, "Types"
A computation involving unsigned operands can never overflow, because a result that cannot be represented by the resulting unsigned integer type is reduced modulo the number that is one greater than the largest value that can be represented by the resulting type.
This behavior is more informally referred to as unsigned integer wrapping. Unsigned integer operations can wrap if the resulting value cannot be represented by the underlying representation of the integer. The following table indicates which operators can result in wrapping:
[skip]
Subtraction
Subtraction is between two operands of arithmetic type, two pointers to qualified or unqualified versions of compatible object types, or between a pointer to an object type and an integer type. See rules ARR36-C. Do not subtract or compare two pointers that do not refer to the same array, ARR37-C. Do not add or subtract an integer to a pointer to a non-array object, and ARR38-C. Do not add or subtract an integer to a pointer if the resulting value does not refer to a valid array element for information about pointer subtraction. Decrementing is equivalent to subtracting one.
For Addition, it says:
Noncompliant Code Example
unsigned int ui1, ui2, usum; /* Initialize ui1 and ui2 */ usum = ui1 + ui2;
Compliant Solution (Pre-Condition Test)
unsigned int ui1, ui2, usum; /* Initialize ui1 and ui2 */ if (UINT_MAX - ui1 < ui2) { /* handle error condition */ } else { usum = ui1 + ui2; }
UINT_MAX - ui1 == ui1 ^ UINT_MAX ==> b ^ 0xFFFFFFFF
For Subtraction, it says:
unsigned int ui1, ui2, udiff; /* Initialize ui1 and ui2 */ udiff = ui1 - ui2;
When ( a < b ), max_a is (b-1), min_a is 0, the result == a + (UINT_MAX - b) + 1, max_result == (b-1) + (UINT_MAX - b) + 1, min_result == 0 + (UINT_MAX - b) + 1, no wrapping.
#include <stdio.h> #include <stdint.h> void main(void) { uint16_t a16 = 0xFFFF, b16 = 1234, r16; uint32_t a32 = 0xFFFF, b32 = 1234, r32; r16 = a16 * b16; r32 = a32 * b32; printf("r16 = %u\n", r16); printf("r32 = %u\n", r32); printf( "r32 mod 0x10000 = %u\n", ( r32 % 0x10000 ) ); system("PAUSE"); }
r16 = 64302 r32 = 80870190 r32 mod 0x10000 = 64302
#include <stdio.h> #include <stdint.h> void main(void) { int16_t a16 = 32760, b16 = 1234, r16, r16_chk = -9872; int32_t a32 = 32760, b32 = 1234, r32; r16 = a16 * b16; r32 = a32 * b32; printf("r16 = %d\n", r16); printf("r32 = %d\n", r32); printf( "r32 mod 0x10000 = %d\n", ( r32 % 0x10000 ) ); printf( "r16_chk = %u\n", (uint16_t)r16_chk ); system("PAUSE"); }
r16 = -9872 r32 = 40425840 r32 mod 0x10000 = 55664 r16_chk = 55664
Modular arithmetic
en.wikipedia.org/.../Modular_arithmetic
(It is too difficult for me, so I simply skip it.)
Never mind, I found a satisfactory answer. If anyone is interested, it's here
groups.google.com/.../5975d5d43d33a914
and here
groups.google.com/.../a23d05b62d198a20
They include those, yes, but they're not limited to those. But they just as well include subtraction, shifts, unary minus. That's why it says "computation", not "addition", nor "addition and multiplication".
But you already found it! It says there is no such thing as overflow on unsigned arithmetic. How much more clear could that possibly be?
Careful dragging that into this discussion. Compliance to some rules that have been invented, with no particular relation to the language itself---which that's about---s an entirely different issue than the well-definedness of operations specified by the language itself.
It is by no means clear that this is even is any kind of "error condition". In the case this thread is about it most decidedly would not be.
There is absolutely nothing wrong with a 32-bit timer rolling over from a starting point of, say, 0xFFFFFF80 to 0x00000003. Plain and simple subtraction of those numbers yields exactly the elapsed number of counts: 0x00000083. Look, Ma, no error!
