#include <LPC214X.H>
//Control lines connected to P0.0, P0.1, P0.2, nad data is connected to P0.4,P0.5, P0.6, P0.7 #define LCD_DATA 0x000000FF #define LCD_SET IO0SET #define LCD_CLR IO0CLR //Control lines connected to P0.4, P0.5, P0.6, P0.7 //#define CTRL 0x000000 //#define CTRL_SET IOSET1 //#define CTRL_CLR IOCLR1
#define RS 0x00000001; /* Set P0.0 */ #define WR 0x00000002; /* Set P0.1 */ #define EN 0x00000004; /* Set P0.2 */
#define LCDRS (1 << 0) #define LCDRW (1 << 1) #define LCDEN (1 << 2)
#define LCD_D4 (1 << 4) #define LCD_D5 (1 << 5) #define LCD_D6 (1 << 6) #define LCD_D7 (1 << 7)
#define LCD_DATA_MASK (LCD_D4 | LCD_D5 | LCD_D6 | LCD_D7) //-------------------fuction declations----------------------- void LcdInit (void); void LcdData (unsigned char data); void LcdCmd (unsigned char cmd); void delay_lcd(void); //void DisplayRow (int row, char *str); void int_port(void); void delay1(unsigned int); void delay(int count); //------------------------------------------------------------------------------
int main () { int_port(); LcdInit(); LcdData('A'); LcdData('B'); LcdData('C'); while(1); } void int_port(void) { PINSEL0=0x00000000; PINSEL1=0x00000000; IO0DIR = LCD_DATA; LCD_SET=(LCDRS | LCDRW | LCDEN); LCD_CLR|=LCD_DATA_MASK; //All segments Off //CTRL_SET= CTRL; // LCD_CLR = LCD_DATA; //All segments Off } //---------------------------------lcd initi-------------------------- void LcdInit (void) {
delay1(5); delay1(5); delay1(5);
LcdCmd(0x01); // LCD clear LcdCmd(0x03); // commands from datasheet delay1(5); LcdCmd(0x03); delay1(5); LcdCmd(0x03); delay(100); LcdCmd(0x28); // Select nibble mode LcdCmd(0x06); // LCD diaply and cursor ON LcdCmd(0x0e); // cursor diraction and link // LcdCmd(0x10); LcdCmd(0x01); // clear LCD
} //-------------------------------------------------------------------- void delay1(unsigned int time ) // delay in ms { int i,j; for (i=0;i<=time;i++) for (j=0;j<=5000;j++); } //--------------------------------------------------------------------- void LcdCmd (unsigned char cmd) { int temp1;
temp1 = cmd; temp1 &= 0x000000f0; // get higher nibble
LCD_CLR= LCD_DATA; // Clear LCD data IO0PIN = temp1; // Send data on port 0
LCD_CLR= RS; // clear RS pin LCD_CLR= WR; // clear wr pin
LCD_SET=EN; // set anable pin delay(5); LCD_CLR=EN; // clear enable pin delay(10);
temp1=cmd; temp1=temp1<<4; // rotate data right temp1 &=0x000000f0; // get lower nibble
LCD_CLR= RS; LCD_CLR= WR;
LCD_SET=EN; delay(5); LCD_CLR=EN; delay(10); } //--------------------------------------------------------------------------------------------------------------- void LcdData (unsigned char data) { int temp1;
temp1 = data; temp1 &= 0x000000f0; // get higher nibble
LCD_SET= RS; // set RS pin LCD_CLR= WR; //set wr pin
temp1=data; temp1=temp1<<4; // rotate data right temp1 &=0x000000f0; // get lower nibble
LCD_CLR= LCD_DATA; IO0PIN = temp1;
LCD_SET= RS; LCD_CLR= WR; LCD_SET=EN; delay(5); LCD_CLR=EN; delay1(5); } //------------------------------------------------------------------------------ void delay_lcd(void) // small delay { int j; for (j=0;j<600;j++); }
//------------------------------------------------------------------------------------ void delay(int count) { int j=0,i=0;
for(j=0;j<count;j++) { /* At 60Mhz, the below loop introduces delay of 10 us */ for(i=0;i<35;i++); } } //-----------------------------------------------------------------------------------
I have a doubt about that my delay routine are not generating correct delay.
Thank u, Heena
Look at http://www.keil.com/forum/14875/
There you will find a good working software delay routine.
Thank u so much sir my LCD is now working fine...
Thank u sir for your advise..
