stellarisif.c
static err_t stellarisif_transmit(struct netif *netif, struct pbuf *p) { int iBuf; unsigned char *pucBuf; unsigned long *pulBuf; struct pbuf *q; int iGather; unsigned long ulGather; unsigned char *pucGather; ........................... [omitted] /* Initialze a long pointer into the pbuf for 32-bit access. */ pulBuf = (unsigned long *)&pucBuf[iBuf]; /** * Copy words of pbuf data into the Tx FIFO, but don't go past * the end of the pbuf. * */ while((iBuf + 4) <= q->len) { HWREG(ETH_BASE + MAC_O_DATA) = *pulBuf++; iBuf += 4; }
The above code is part of the latest version of the TI/Luminary StellarisWare.
I think it is a bug? And I hope to fix it with
__packed unsigned long *pulBuf;
in the KEIL toolchain. (Tested.)
But due to my very limited C programming skill, I am afraid that, I might be doing something stupid. So I would like to learn something from our experts, please kindly give me some advices.
Is that, the __packed qualifier (in this case) leads to the lower performance?
Some people are of the oppinion that source code should not contain any comments. That comments are only needed when people have selected bad symbol names. Hopefully, they only have a view, but don't spend time actually writing code.
Good code allows the reader to understand what happens just from looking at the code without need for comments. But it's really important that source code comments exists that does describe reasons for the actions. It doesn't matter if I can see code and understand that the code is sorting something, if it isn't obvious why that something needs to be sorted.
But an even more important thing is that any assumptions should always be very clearly documented. And the code should, if possible, try to contain (at least for debug versions) code to catch invalidated assumptions.
A problem is of course that we make a lot of assumptions without realizing that we are. But assuming that buffers have specific alignments really are assumptions that the code creator must have been well aware of making. And it should have been just as obvious that such an assumption has to be clearly documented. All functions that does rely on this should basically prove their right to do so.
Dummy post just to correct the extra characters I managed to get in my name. Some times when I try to answer a thread, the web browser moves the focus to the First Name field after I have already clicked the Message box and started to print characters. I haven't checked if there is any javascript OnLoad function that gives this result, but it has happend quite a number of times :(
The latest response from TI/Luminary:
e2e.ti.com/.../261784.aspx
John,
Cortex-M3 will handle some unaligned data accesses, but not all. If you do a "ldr" or "str" to load or store a value, unaligned addresses are handled seamlessly (unless you explicitly disable unaligned accesses, which is a control bit in the NVIC CFG_CTRL register). However, if you do a "ldm" or "stm" to load or store multiple values (where "multiple" is defined as 1 or more), unaligned addresses are never allowed.
In the Keil compiler, there are certain situations where "*pulPtr++" is coded as a "ldr", and others where it is coded as a "ldm". This seems to be a recent change in their compiler, as we have seen this problem crop up with some of our applications due to this exact code construct (though we have not seen any issues in lwIP). I do not know what the heuristic is to determine when they will and when they won't use a "ldm". However, it appears as though the "__packed" qualifier will force it to use a "ldr", which is compatible with unaligned addresses. This explains why the use of "__packed" makes your problems go away.
Avoiding unaligned pointers will also solve the problem. Note that this is a problem that is specific to Keil; this code is compiled to "ldr" instructions by all the other supported tool chains.
--Brian
This afternoon, right after I posted some more information on the TI/Luminary forum, and it was almost time to go home, my supervisor told me that, I will be laid off before the end of December, maybe earlier, before the end of November.
The company I am working for, have been suffering persistent losses for quite a long time, and our main products are all classic 8051 based. As the only ARM software engineer in the company, such a lay off did not surprise me.
But I do hope that, I can have more time to finish all my three projects, then ask them to freeze all the source code and binary. I just don't want someone fiddles my projects, then adds some terrible bugs.
I understand that, it is just a hope, it is never possible.
Very sorry to hear that.
All the best for the future...
Sorry to hear.
Hope you'll find some other job quickly.
Maybe your company should have taken a closer look at their options - maybe some of their losses are caused by they staying with 8051 chips when competitors moves to ARM chips. The ARM chips tends to give a bigger flexibility, and have better peripherials. So way easier to react to a customer requirement late in a product life cycle.
About the align problem - funny guys. Writing C code where they ignore the C standard and don't make sure themselves that their casts are aligned. And then blame the compiler for their oopses. I think they may have a developer or two who should consider a different way of earning his/her daily food.
A similar though occurred to me: they have a loss-making, lacklustre 8051-based product range - so they've fired the guy who could give them the shiny new product to rescue the company...
I'm very sorry to hear that. Per and Andy made a very good point - the low performance processors might play a role in this affair - but I'm afraid that now it is too late - not only because you were fired, but mainly because the transition will be costly in terms of man hours and hardware design and compliance tests etc...My employer made that very same transition (there are still some 8051 products solved, of course, but the future belongs to ARM7 and in particular, CM3/LPC1788 chips) about 2 years ago - they hired me and some others and we just nailed it. Either way, I believe I speak for all of us by wishing you all the best in the future.
Many thanks to all. (My English ability is very limited, not able to discuss something non-technique properly and fluently.)
==> About the align problem - funny guys. Writing C code where they ignore the C standard and don't make sure themselves that their casts are aligned. And then blame the compiler for their oopses. I think they may have a developer or two who should consider a different way of earning his/her daily food.
I was confused by the latest response from TI/Luminary. I thought it was due to my lack of programming knowledge.
But now, I think my confusion is quite reasonable. But I am not sure if I have enough knowledge to deal with TI/Luminary and this issue, and I am running out of time.
Hi, good morning, I want to go out with my wife and kids for breakfast now. I chose this job, because it gives me an opportunity to accompany my family in southern Taiwan.
My supervisor told me that, the lay off is actually a 20% - 40% employee downsizing. So I am not the only one involved.
It seems that, this downsizing was originally scheduled in next year Q1 or Q2, but brought forward to the end of December, due to the USA Fed is launching its second round of quantitative easing, which leads to sharp appreciation of the Taiwan Dollar exchange rate.
It seems that, Euro/Great Britain Pound/Swedish Krona are relatively stable? Many countries in Non-Japan Asia will be seriously impacted.
As Tamir pointed,
==> now it is too late - not only because you were fired, but mainly because the transition will be costly in terms of man hours and hardware design and compliance tests etc...
And the marketing research will also be needed, if we want to do it right.
Maybe my software development skill is better than the "average" level of our "local" competitors, but one software engineer is not able to do much under such a tough condition.
Many local small companies here in Taiwan, were just suddenly shutdown; and the owner of company just magically disappeared, left the angry employees and suppliers. Even the famous TSMC, in 2008, they forced their employees to resign, so that they did not need to pay the severance fee. And then, in 2009, when they needed the experienced employees, they said it was a mistake/misunderstanding, they were very sorry, they wanted to re-employ all the laid off employees. So, I believe that, the owner of the company which I am working for, is a good man; he chose to "try to" officially lay off the employees. Though he made a lot of wrong business decisions.
I don't like northern Taiwan, but I may have to work there once again, since there are more jobs.
