LX51 overlapping code with no warnings/errors
Hi there,
I am currently seeing a relatively strange occurrence with the Keil compiler and linker overlapping two pieces of code into the same code area without showing any warnings or errors to the user.
Here are the details:
* Compiler/Linker versions:
CX51 COMPILER V9.02 - SN: K1NCC-YA1WVE
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2010
LX51 LINKER/LOCATER V4.47a - SN: K1NCC-YA1WVE COPYRIGHT KEIL ELEKTRONIK GmbH 1995 - 2010
* Attached map file (linker_overlap.map), lines 651 - 653:
00CD88H 00CD93H 00000CH BYTE UNIT CODE_TIMER/B3 ?PR?_TIMER_INIT?TIMER
*** OVERLAP ***
00CD89H 00CD95H 00000DH BYTE UNIT CODE/B3 ?L?COM000A
The linker is clearly overlapping two functions (timer_init and a linker optimized code block) in the same code space, causing timer_init to contain invalid code. It clearly detects it during linking, since it prints and *** OVERLAP *** message in the .map file, but it shows no errors or warnings.
* Additional details:
- Multiple libraries linked in with a mix of linker code packing enabled and disabled per library.
- Warning level set to 2 in the .lin file (WARNINGLEVEL(2))
- Optimization level set to 9 (Common Block Subroutines) in all libraries
Thanks in advance!
Carles
  • This won't solve your problem, but can be a hint:
    I also had some problems with code banking and optimizing. There were was a bug in CX51/LX51 and I managed to narrow the problem to just a few lines of code and sent it to Keil, so they could reproduce the problem. Needles to say, it was fixed... At least you're lucky that LX51 detects faulty condition - our code compiled/linked without errors/warnings but crashed (very) occasionally. Luckily, target was C8051F120 with JTAG debug so I managed to pin-point the problem, otherwise I would probably still be scratching my head...
    - Dejan
